Eibach Prokit
Old May 7, 2005
blackcivic03's Avatar
blackcivic03 is an unknown quantity at this point
Red face Eibach Prokit
Im installing the Eibach Prokit with is estimated to be a 1" drop. However some people on the forum advertise there car dropd "1.25 inces to nearly 2" inches. I dont want to drop my car any more then an inch because im using stock struts. (yes I know)
1) Does this kit drop lower then 1 inch?
2) also is there a spring thats a little higher then the pro-kit?
I searched the FAQ, and couldnt find a positive answer so any help is appreciated! Thanks
btw the FAQ's really helped
Old May 7, 2005
robbclark1's Avatar
Retired suspension supermod.
1) yes, you won't be able to tell the difference between 1" and 1.25" anyway. It will be so close to stock.
2) no
Old May 7, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
The shocks are gonna blow anyways, so it doesn't really matter how far they drop the car.
Old May 7, 2005
well i dont have 600 for a coil-over kit...........
Old May 7, 2005
im just hoping to get at least 20k miles out of my stock struts, then ill replace them with new oem struts. its a lease anyway so by that time ill trade it in.
Old May 8, 2005
flotsamm's Avatar
Since your going with the Pro-kit, your odds of blowing them are less then with other springs that have lower drop. I rode around woth my Sportlines for over a year without any problems, and they were still fine when I swapped them out for some Koni's.
Old May 8, 2005
dacivic's Avatar
dacivic is an unknown quantity at this point
Prokit left about 3 fingers gap. You should be aright for a long while with them.
Old May 8, 2005
thanks
Old May 8, 2005
After a few months, mine is about 2 finger front and 1 finger rear. I'm staying on stock struts then getting tokico hp later.
Old May 8, 2005
looking good
Old May 9, 2005
civicph's Avatar
civicph is an unknown quantity at this point
tein h techs
if you want a less than 1" drop you can get tein h techs 0.8" drop
Old May 9, 2005
legacyse's Avatar
legacyse is an unknown quantity at this point
hey gearbox, your car looks nice.
Just want to make sure, you are on eibach prokit correct? ur car seems very low and according to you there's only 1 figure gap in the rear. I'm currently looking into lowering springs but i don't want it to be too low. prokit claims 1" drop all around, but in ur case is more like 2" ? Damn i hate my car current's stance, i can fit my fist in
Old May 10, 2005
nitroal1973's Avatar
Broken Road......
nitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to all
I have a prokit, and have 2-fingers all the way around.
Old May 11, 2005
Nameless's Avatar
TURTLEonK
Nameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the rough
on my 02 sedan, i have the prokit with tokico hp blues and my rear is half a finger to a finger and my front is a finger and a half.. my rear is also a bit lower cuz i have a subbox in the trunk...
Old May 12, 2005
btw there's only a small amp and some neons in the trunk. So its not lower cause of that. Also I noticed the car was already kinda low compared to other civics before I put the springs on..
Old May 12, 2005
PennyKnotOff's Avatar
That's the rear of my civic it's about a 1 finger gap maybe 1.5 but the front 2 finger gap so it did go pretty low but a clean drop
Old May 16, 2005
slickdip's Avatar
slickdip is an unknown quantity at this point
hey penny, ^^ looks like u got rims on ur car too, so the gap is probably smaller cuz of that?
i am getting my pro-kit installed next week, and i want to stick 18's on my car, do u peeps think there will be any rubbing?, also does anyone have a pic of this kind of a setup
Old May 17, 2005
Think 18's will look good definitely close the gap more then steelies would depending on the tire size you good w/ but pently of people have 18's w/ a lower drop then the prokit so you shouldn't have any problems but I suggest get a camber kit and some new shocks as soon as you can afford to.
Mad Dog Tannen
Oct 19, 2016 08:12 PM
Viczhou
Sep 2, 2015 07:55 PM
Shadow277
Aug 31, 2015 12:30 PM
cukaracha
Aug 29, 2015 05:27 PM
protoCall7
Bolt-on Engine Performance
Jul 26, 2015 07:41 PM
