Adjusting rear camber and toe
Old May 17, 2005
P40vic's Avatar
P40vic is an unknown quantity at this point
Anybody have a sense of how much the rear toe changes when the camber is changed? I want to change my current camber settings by .5 or so for autocross (SPC upper arms) and I'm wondering if the toe will change much. Hate to do another alignment right now, hopefully saving it until later when I do front suspension changes.
Old May 17, 2005
tfnaaf's Avatar
BLDNPSI Mod
It will change toe, and the change will varry with ride hieght.
Old May 17, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
Rear toe won't change much with a camber adjustment. You can adjust the toe with the rear lower knuckle bolt. Loosen the locknut, turn the cam, then retorque the locknut to 43 lb ft.
Old May 17, 2005
P40vic's Avatar
Thanks for the feedback; I think I'll go ahead and change the camber and get the toe checked later, it was recently set with .04 toe in so even if toe changes in/out a little, it probably won't make too much difference.
GolNat
Jan 12, 2021 09:06 PM
sccarally
Texas
Aug 21, 2015 10:09 PM
Curtchuk
Aug 5, 2015 02:14 PM
