Need info/advice RE: Struts
Old Apr 30, 2005
brill's Avatar
brill is just really nicebrill is just really nicebrill is just really nicebrill is just really nice
Yeah, yeah, there are plenty of posts on it but I'll give points + rep for those who understand my post, answer me politely with "meat & potatoes information" and leave all the 'search' bs out of their posts. Look at my point balance, I can afford to be generous to those who are kind.
At 109,000 kms, my front struts are hereby leaking -- again. This time however I'm not under warranty. The car is an '02 sedan... My area has very brutal rough roads (actually its interesting only 6 months after moving back here is when my struts start giving me grief)
I'm not willing to pay $700 CAD to have Honda struts installed again, given they just don't last. Perusing posts around this board prove that, as do my own experiences. A car this light shouldn't be blowing struts -- they're sh*t. We all know it.
I DO NOT want to lower, under any circumstances. I light my ride height. My questions are as follows:
1. What the hell is a strut anyways? -- I'm a travel agent not a mechanic.
2. Are there any parts that should be replaced with the struts, if I were to invest in aftermarket?
3. Is there a particular brand that I should be looking into that is known to have better reliability and proven success?
4. What can I expect to pay (please provide what currency you're speaking in) for aftermarket strut installation?
Thanks to those who answer deserving of my promised points & rep.
~B
Old Apr 30, 2005
robbclark1's Avatar
Retired suspension supermod.
1) The front strut is a Macpherson strut meaning there is a mount with a shock built into it.
Macpherson strut: Definition: A special kind of oversized shock absorber that's used as part of the vehicle's suspension. When used on the front suspension, it replaces the upper control arm and ball joint. Some struts have coil springs around them while others do not. Some struts have replaceable internal components that can be repaired by dropping in a new cartridge.
Go to google and type "define:Macpherson strut"
http://www.google.com/search?hl=en&l...cpherson+strut
2) You shouldn't need anything else unless you want to get new upper mounts. They might be worn down a bit and don't cost very much. www.hondaautomotiveparts.com
3) If you don't want to lower and are looking for daily driving quality, then stick with Tokico blues. They will swap right in with your stock springs and stock upper mounts.
4) They cost about $400US and if you don't DIY, then expect to pay whatever shops charge for install. You can get them from peteriap, dezod, namotorsports, robbearracing, ebay, etc.
Truehonda is having a sale!!
http://www.7thgencivic.com/forums/sh...d.php?t=207784
Old Apr 30, 2005
1955's Avatar
KGB struts is what i have now and its much better than stock ones,handling is great,$85 ea in US currency from importrp dot com, stock height and ride too.
Old Apr 30, 2005
robbclark1's Avatar
The KGB still exists?? haha Just kidding. They are KYB GR-2's.
Brill there is a big strut/shock/damper thread at the top of this forum. Check it out.
Old May 1, 2005
brill's Avatar
Thanks robbclark1, your post was of great assistance. 5000 Points to you. I can't provide you with Rep as you have it disabled.
500 to you 1955.
Old May 1, 2005
robbclark1's Avatar
Brill, when you order shocks, make sure you get the ones from the right year. If you have an 01-02 then there shouldn't be any problems. 03+ has 16mm mount bolts and might have to be drilled out or order specificially for your application.
Here are som pretty cheap tokicos.
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
My friend has them and has had no problems. Gr-2's are comprable, but I dont' know as many people that have them.
Old May 1, 2005
brill's Avatar
I'm going to try some local auto supply stores here in town the next weekday i get off. Support the local economy
Love living in a small town.
and I have an '02 so shouldn't have a problem fitting. I notice they usually specify the years they are for.
Old May 1, 2005
AlienX's Avatar
AlienX will become famous soon enough
big + on the tokicos.. life time warrenty. Think about blowing those
Old May 1, 2005
brill's Avatar
yes i read that on their site. sounds like they stand behind their product.
Old May 1, 2005
AlienX's Avatar
i have them on a 2 inch drop and they havn't failed yet, keyword. On a stock drive, you should see a huge improvement.
Tedverseti
Apr 23, 2020 01:45 PM
SammySC
121
Apr 7, 2017 07:43 PM
skeener51
Oct 1, 2015 05:56 PM
ken4444
Sep 30, 2015 07:37 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
