need some help with some specs
Old Apr 28, 2005
rino's Avatar
rino is an unknown quantity at this point
ok so I have had this set up for about 2 yrs and then my car was hit and so I had the shop just replace everything the same way. I have neuspeed sport springs with a camber kit with 205/50/16, I dont know the offset. Before the wreck the alignment shop was able to get my camber very close and ended up being like -.4 or so on the rear. Well now with the same exact set up the alignment shop cant get it closer than -.9 without it rubbing my fender. I haven't tried it out to see if it will really rub just going from what they say. The problem is that my tires are definately going to wear fast because it is too negative. It looks like this / \. It is very noticable to the naked eye, whereas before the accident you couldn't really tell if it was off or not and I had very little tire wear. Can someone suggest what to do.
Old Apr 28, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
Well its not too negative. Less than a degree won't do anything if they set your toe to 0. I've been running -2.25 for the last 10 months and you can't see it in my tires.
Old Apr 28, 2005
rino's Avatar
hey boiler, you are set to -2.25, so you can noticibly tell that your wheels go in / \ in the back. I mean the shop told me they set it to -.9,-1 but it just looks really neg. in my opinion. I need to call and make sure my toe is set to 0 though. Thanks.
Old Apr 28, 2005
Jap-Euro Fusion
Oh, in the back? Ha. **** it. Spec in the rear is -1.5 or less. I've got -2.25 in the front. My rears are like -1.7.
Tedverseti
Apr 23, 2020 01:45 PM
Elciteeve
Sep 28, 2015 12:40 PM
fvckbg
Sep 8, 2015 09:55 PM
thaler4cuse
Sep 7, 2015 08:25 PM
Jul 12, 2015 11:54 AM
