Rear Wheel Bearing
Old Apr 27, 2005
K20EQUIPPED's Avatar
K20EQUIPPED is an unknown quantity at this point
Rear Wheel Bearing
Hey Guys,
My bearing on the passenger rear has taken a sh|t and Im going to be changing it this weekend...Anything I should know as I have not changed a hub unit on a civic with drums....
Any tips would be helpful...
Thanks
Old Apr 27, 2005
streetglower's Avatar
it should be pretty easy. remove the drum, remove the dust cap, nut, and other nuts holding hub on, remove and replace with new one.
Old Apr 28, 2005
etdigitalis's Avatar
etdigitalis should not be trusted
aside from just a new hub, you're going to want to replace the spindle nut. one side is going to be locked into the end of the spindle by a "dimple" which you're going to have to bend-out to get it off.
when you put the new one on, use a little bit of engine oil inbetween the nut/hub and tighten it to 134ft lbs. afterwards, use a drift pin and a hammer to bend that nut back in there.
Old Apr 28, 2005
thanks,
it is a simple job, just wanted to make sure there are no hick ups that could have been avoided
Thank You
GolNat
Suspension DIY
May 12, 2022 06:49 AM
edspyhill09
Jun 12, 2016 02:45 PM
cmart1209
May 29, 2015 04:52 AM
bsmiley
Apr 27, 2015 01:27 PM
crazydragon
Nov 7, 2001 05:13 PM
