rear lower tie bar
Old Apr 18, 2005
thefivespeeder's Avatar
thefivespeeder is a jewel in the roughthefivespeeder is a jewel in the roughthefivespeeder is a jewel in the rough
rear lower tie bar
hey i just got a rear lower tie bar, i thought it would be real easy to install, but now looking at it, it seems to be a little more complicated, can someone please give me some detailed instructions before i break something else on the car...thanks
Old Apr 18, 2005
half_n_half17's Avatar
half_n_half17 is an unknown quantity at this point
It should just be a few bolts. Jack up the rear end of the car and put it on some jack stands and you should be fine. It took me about 45 mins start to finish to get mine on.
Old Apr 18, 2005
teampointless's Avatar
Ultimate Member
check the DIY install for the Progress rear sway bar. Instructions are in there for the tie bar also.
Old Apr 18, 2005
thanks guys
Old Apr 18, 2005
VTECTypeR's Avatar
The only hard part is aligning the control arms.
Old Apr 18, 2005
Yoyoio's Avatar
Yoyoio is an unknown quantity at this point
what my tech did was. hoist up my car, air gun out the bolts, bar on, air gun in the bolts. didn't use nothing or holding anything.
Old Apr 18, 2005
flotsamm's Avatar
I used a wooden dowel to hold it in place as I was removing the bolt. I didnt want the LCA to drop out. Then after I put the bar on(one side at a time) I removed the dowel as I was screwing in the bolt.
Old Apr 18, 2005
CuRiOuSfIsH's Avatar
Back From The Banned!
^^ my brother used the same method.
Dorval Andre
May 1, 2015 09:37 AM
bluecoupe
Dec 19, 2001 10:08 PM
Daniel420
Dec 4, 2001 08:46 PM
0100010
Bolt-on Engine Performance
Nov 26, 2001 07:50 PM
BiGbRoWn
Nov 21, 2001 06:17 PM
