*updated w/pics* Tein Basics...(problem solved)
Old Apr 13, 2005
flyers27's Avatar
Broad Street Bullies
flyers27 is an unknown quantity at this point
Just installed tein basics. No real problems exept for one. I can only set it for 1 1/2 finger gap in the front and 2 finger gap in the back or else the tires sometimes rub over bigger bumps. seems like when they are set to 1 finger gap there is so much difference in the stiffness. they are so much less stiff with one finger more of a drop from where they are now. i think the problem may be that i have 215/45/17. Maybe the 215 width is the problem cause it sounds like the outsides are the parts that are rubbing. Anyone else have this size of tire with a lower ride height and rubbing issues (especially people with tein basics)? thanks
Old Apr 13, 2005
hustlelikem0fo's Avatar
those tires sound a little too big if you want to get rid of wheel gap.... if you had 205/40/17 then you could probably go as low as you can and not rub. i have TeinSS which are ssame as Basics only with dampers.... i'm tucking 215/35/19 in the rear and the front has like half a finger gap and i dont rub. so i think its the tires
Old Apr 13, 2005
flyers27's Avatar
might be....seems like the tires come out pretty wide. It looks like it would rub if it could. Anybody else have this tire size and same problems?
Old Apr 13, 2005
silverem2's Avatar
post pictures of your setup if you can, Im thinking about buying those
Old Apr 13, 2005
flyers27's Avatar
i wll post up pics tomorrow night....after work
Old Apr 14, 2005
flyers27's Avatar
whatcha think, tires too wide? cant be slammed? i want a one finger gap!
Old Apr 14, 2005
flyers27's Avatar
bump for picture......anyone have an answer?
Old Apr 14, 2005
runner1738's Avatar
yes if you want it slammed then yes you got hte wrong tire size if you want as much cushion as possible then you got the right size, but imo it looks perfect to me drop and wheels
Old Apr 14, 2005
you definatly need to lower the rear more.... it doesnt even look dropped in the back. front looks good though
Old Apr 14, 2005
zachgeyer's Avatar
4x4 lol
Old Apr 14, 2005
flyers27's Avatar
if i drop it more......it rubs over bumps. donat know what to do.
Old Apr 14, 2005
flyers27's Avatar
theres more pics in the members ride forum that i just put up. what should i do?
Old Apr 14, 2005
BananaSkin's Avatar
BananaSkin is an unknown quantity at this point
If you want to lower it more you'll need different dimension tires.
Old Apr 14, 2005
runner1738's Avatar
change the tires or live with it until they wear out
Old Apr 15, 2005
jttegx's Avatar
OMNES AD UNUM
or sell and get some 205/40 or 215/40 ?
Old Apr 15, 2005
flyers27's Avatar
the tires are brand new Nankangs (215/45/17). 1000 miles on the rears and 75 miles on the fronts. should I sell just the tires on ebay or something or should i sell them as a whole package with the rims. then i would have to uy a package with 16 inch rims. how much do you think i could get for them seperately or together. or do you think someone would trade here on the forum for 16's.
Old Apr 15, 2005
Vinnie's Avatar
Vinnie should not be trustedVinnie should not be trustedVinnie should not be trustedVinnie should not be trusted
This is my setup: Tein SS with Falken's that are 215/45/17 also.
REAR:
FRONT:
Old Apr 15, 2005
flyers27's Avatar
why do mine rub? dont understand....you have about one finger gap, and i have two finger gap in therrear and 1 3/4 in the front.
Old Apr 15, 2005
phuviano's Avatar
Slowest 7thgen in the GTA
Question for both Vinnie and flyers27.
Do u guys have camber kit??
Old Apr 15, 2005
Vinnie's Avatar
Yep, I have SPC front and rear.
Alignment shop was able to set the adjust rears perfectly. The fronts have still have negative camber but the toe is good, hopefully my tires dont get chewed.
Old Apr 15, 2005
civicvtec1ps's Avatar
Search and Learn
215/45/17
17x7
offset 43+
Tein ss
I had one finger gap all over, maybe less than that.
Didn't have any problem with rubbing.
Didn't have camber kit either.
Check your wheel offset, that might be the problem,
Just play around with it..
You can lower rear suspension lower than that without any rubbing.
Old Apr 15, 2005
flyers27's Avatar
just switched back to my stock rims and tires and even lowered the car a little more to a tight two finger gap and have no rubbing. It has to be my rims and tires. The rims are 17x7 215/45's just like yours. And yes i have a SPC front and rear camber kit. Where can i find out the offset because when i had my aftermarket rims on before the tires looked like they were out pretty far compared to the fender. I guess i have to keep my stock five stars on and sell my rims. IDK what do you guys think? Anyone interested?
Old Apr 16, 2005
phuviano's Avatar
You can either sell the tires, and try 205's and see if that works. I have the same problem as you right now. I was almost going to order my tein basics, untill I saw this thread. I have the exact same tire size, and same rim width.
My tires almost line up with fender. If I lower my car, I know I'll have the same problem as you. I know I could probably get away with this problem if I don't get a camber kit, cause the tires would tuck inward at the top. I don't want camber wear on tires that I spent a lot of money on though.
I've decided in the long run, that I don't want to change over the tires, cause I'll probably lose money. I think I'm just going to 4x4 since I drive my car in the winter too.
With the extra money that I save for my tein basic, I'm going be spending it on an HID kit instead... woohoo !!!
Old Apr 16, 2005
I was thinking.... maybe you should run a little negative camber in the rear? that way you'll be able to go low and the tires would clear the fender if they're cambered in a little.
Old Apr 16, 2005
dirtySAMURAI's Avatar
I log in from time to time
roll fenders? cut fenders? try one of the two...
Old Apr 16, 2005
flyers27's Avatar
Roll fenders? Do you mean that lip inside the wheel well? I was thinkin of tryin to bend that up since that is what was rubbing the tire but i thought as i bent the lip the paint will not bend with it and it will chip potentially on the oitside of te fender as well as the inside.
Old Apr 16, 2005
MisterFrankieJ's Avatar
MisterFrankieJ will become famous soon enoughMisterFrankieJ will become famous soon enough
I've heard that some people use a heat gun to heat up the paint so it doesn't chip.
Old Apr 16, 2005
flyers27's Avatar
thats crazy.....i would never mess with that.
Old Apr 16, 2005
flyers27's Avatar
new problem now......just put on the stock roms and tires and lowered the car to 1 1/2 finger gap no more rubbing, but the rear passenger side is clanking over bumps and not the other side. Everything is the same (height, and amount of dust cover that was cut, no added weight in the back or anything) WTF, one problem to the next. Any ideas on what it could be?
Old Apr 16, 2005
Wolfgang5884's Avatar
those wheels look fancy
