215/35/18 rubbing or any problems?
Old Mar 20, 2005
asc070's Avatar
asc070 is an unknown quantity at this point
I just recently bought 18" rims and I got the rubber for it.
I ended up getting the Kumho Ecsta Supra 712 in 215/35/18.
Just wondering if i'm going to have any problems with that rubber or is it to low in the profile.
Also how low can I drop my car without any rubbing???
Old Mar 20, 2005
NoLeadEmSoMuch's Avatar
NoLeadEmSoMuch will become famous soon enoughNoLeadEmSoMuch will become famous soon enough
Don't know how low because I'm not dropped, but I have no issues with mine.
Old Mar 20, 2005
xDCx's Avatar
xDCx will become famous soon enoughxDCx will become famous soon enough
be extra careful wit potholes/deep cracks or whatever in the road wit the low pros...gon be a bumpy ride
Old Mar 20, 2005
xDCx's Avatar
im lowered to one-finger gap n got plenty of space.
if u plan to go that low or lower, be sure to get camber kit asap.
i ride on 215.35/18s
Old Mar 20, 2005
tamazoid's Avatar
tamazoid is an unknown quantity at this point
i got 215/40/18 and i'm pretty much tucking all 4 corners with no camber kit and mine's fine... the only time i rub is in the front left corner when i take very hard turns...
so you should be fine...
Old Mar 20, 2005
xDCx's Avatar
^umm take a look at ur rear tires.
if they are like this / \
even slightly, then i recommend
u need a camber kit
Old Mar 20, 2005
tfnaaf's Avatar
BLDNPSI Mod
u need a camber kit
soo true, BUT! If they are tucked then he wont be able to correct the camber without the tire rubbing!
Old Mar 21, 2005
tamazoid's Avatar
u need a camber kit
i like the cambered look... and at my height, i can't use a camber kit anyways unless i raise it up a little...
Old Mar 21, 2005
skiboard's Avatar
Doesnt your tire hum alot if you have negative camber?
cause I just got mine ,215/35/18 on Neuspeed Sport it tucks abit
and makes kinda loud humming sound
Old Mar 21, 2005
Nameless's Avatar
TURTLEonK
Nameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the rough
^ might just be ur tires making that sound? cuz I get that too but I havent lowered yet
Old Mar 22, 2005
xDCx's Avatar
ha gotcha...how long have u had it like that? is the tire-wear real bad? do u drive long distances in ur car? cuz i don't have a camber kit yet, ha, but im usually drivin jus to school n work which is 5 minutes away from home...
Old Mar 22, 2005
tamazoid's Avatar
i don't really notice any humming noises from my tires... but i think that's becuase my exhaust is too loud...
i have the falken ziex ze-512 tires. i've had them for about a year now... i say drive quite a bit... well i use about a tank of gas a week almost. and i've been on a few road trips. i always get my car regularly maintained at honda, so my tires always gets rotated... the tire-wear is not too bad, but noticable. the tires that really camber are the rears... the fronts don't really becuase of the mcphearson front struts we have.
i say u should be fine without a camber kit. but that's totally up to u.
Old Mar 22, 2005
blue2k2ex's Avatar
blue2k2ex will become famous soon enoughblue2k2ex will become famous soon enough
Performance tires are gonna be louder then stock and my guess is with that offset and an extreme drop your gonna rub. As far as camber have the alignment done after the drop and see how toed in the rear is. I'm on 17's with neuspeed sport and I ate tires up with out a camber kit in the rear. But with 18's you might not have the same camber issues.
cmart1209
May 29, 2015 04:52 AM
Pudnite
May 9, 2015 07:51 PM
ORskier
May 7, 2015 04:54 PM
nontypical
May 4, 2015 04:10 PM
Ian SFBA
Interior DIY
Apr 25, 2015 02:25 PM
