Installying Type S rear sway bar
Old Mar 10, 2005
03RSX-S's Avatar
03RSX-S is an unknown quantity at this point
I bought a type S rear sway bar for my mom's car for $30 shipped, and I was wondering what hardware I'd need to install it? It came with endlink bushings. I was wondering if i can reuse the stock brackets or will I need to get myself some new ones? Its a 2002 EX Sedan if that makes a difference
Old Mar 10, 2005
PoorCollegeBoy's Avatar
Stolen digital camera = no ninja picture for me
PoorCollegeBoy is a jewel in the roughPoorCollegeBoy is a jewel in the roughPoorCollegeBoy is a jewel in the rough
Just jack up the rear end and have a look, it is really simple. I think all that I needed was a wrench...
Old Mar 10, 2005
03RSX-S's Avatar
so i can use the stock brackets/busings/bolts? I know how to install a sway bar...just wondering if I need any extra hardware to install it.
Old Mar 10, 2005
I used all of my stock parts, including the endlinks and everything has been fine. Be sure to lower the car down slowly from each side so you dont snap the endlinks though.
Old Mar 10, 2005
bobsagator's Avatar
bobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of light
To get the bar off the endlinks you'll need a 5mm allen wrench and a 12mm box wrench. All bolts and brackets fit the new bar. And be sure to grease up the bushings.
Old Mar 10, 2005
robbclark1's Avatar
Retired suspension supermod.
You need 19mm bushings for the RSX bar but you can use stock civic brackets. Bolts and endlinks are fine.
Old Mar 17, 2005
03RSX-S's Avatar
the sway bar came in today
just wondering do I need anything else to install it? Reason I'm asking is on the endlink part it seems like its just a bolt that goes thru it with the rsx bar...while with my integra type r bar I needed bushings in the endlink holes.
Old Mar 17, 2005
robbclark1's Avatar
No bushings for the endlinks. All you need is the bar, 19mm bushings and the stock brackets.
Rogelio Rey
May 24, 2015 08:30 PM
Dorval Andre
May 1, 2015 09:37 AM
bsmiley
Apr 27, 2015 01:27 PM
jessepimpride
Nov 13, 2001 05:59 PM
CapYoda
Nov 11, 2001 05:17 PM
