noise from springs
Old Mar 9, 2005
JDMwhoreCivic's Avatar
JDMwhoreCivic is an unknown quantity at this point
noise from springs
why is it that whenever i turn the wheel you hear a clinking noise and then the alignment gets pulled that way until you turn the opposite way.
okay, so i changed from ground control coilovers because of the noise when turning... to skunk 2 springs....and... the noise is still there.? i dont get it.
Old Mar 9, 2005
Boggie1688's Avatar
Diamond Member
Boggie1688 is an unknown quantity at this point
If i can't figure why my car is creaking or anything. I just take a can of wd40 or some type of automotive grease and just start painting it from were ever the sound is coming from. Give that a shot.
Old Mar 10, 2005
hmm i guess.. but no other car does this.
Old Mar 11, 2005
VNlilMAN's Avatar
The Standard One
coil bind..
pretty much the uppermounts arent doing its job and isnt spinning freely so the springs are trying to. thats one reason why i didnt like the ground controls...
You can try greasing the upper mounts or maybe even try to fit [stock] bearings on it.
Old Mar 11, 2005
Ev1dence's Avatar
Ev1dence is an unknown quantity at this point
this may seem like a dumb reply, but if the arrows on your upper mount are not facing outward the spring will move around when you turn. That will give you a nice clank noise, try removeing your your whole assy and aligning them agian, and make sure the spring is aligned properly also
Sep 26, 2023 06:44 PM
WaryDriver
Aug 22, 2015 06:50 PM
loosescrew84
16
Aug 11, 2015 07:08 PM
Curtchuk
Aug 5, 2015 02:14 PM
mHo2
Jul 27, 2015 12:57 PM
