alignment question
Old Feb 26, 2005
ACURAwerx's Avatar
ACURAwerx is on a distinguished road
alignment question
Hey i just went to get my car aligned.. all 4 wheels. It's been a year, and i'm sure my car is out of alignment. So i drop my car off and come back in about 20 minutes.. and to my surprise the car is sitting outside. The guy told me it would take an hour ! by the way.. my car is lowered on neuspeed race springs. So i pay for it and he tells me.. well your car isn't aligned all the way.. "you need a camber kit to do that" then i said.. I HAVE A CAMBER KIT! Then he says..o well you can only adjust one so much. blah blah blah.. He told me to try to get "additional parts" for my camber kit and all this other bs. I have ingalls camberkit and the people that installed it said its the best quality you can get. My question is.. is it true that you can't get accurate alignment with a lowered car? the guy said the tires will still wear weird and stuff.. and i'm just like , why am i paying for alignment when my tires won't be aligned? I thought that was the whole purpose of the camber kit. the people who aligned my car last year didn't say anything about it. There is a copy of my alignment paper on the attachments, can someone who knows about alignment tell me if they were telling me the truth. I have a feeling that they didn't adjust my camber kit or something cuz they said i didn't have one. thanks guys
Old Feb 26, 2005
robbclark1's Avatar
Retired suspension supermod.
Dude, you got ripped. The rear is close to spec but slightly out. Ingalls should be able to handle more than that. I think you need to find a race alignment shop that knows how to deal with lowered cars. He could have definitely done better than that.
Old Feb 26, 2005
ACURAwerx's Avatar
They said no one could do better then they did or adjust the camber more and if i found someone that could, i could bring it back.. should i ask for a refund? do i deserve a refund?
Old Feb 26, 2005
ACURAwerx's Avatar
Old Feb 26, 2005
robbclark1's Avatar
I don't know what to tell you. I am sure there aren't many racing shops in DE, but I am 99% positive that they could get less than -1.7 and -1.8 camber in the rear. I have -.8 and I have plenty of room. The only thing that could possible confuse them is if the camber kit was not "set up" properly to begin with. The two arms of the camber kit should have been about equal length when installing the kit.
Old Feb 26, 2005
ACURAwerx's Avatar
with the specs i have now, will it really make a difference if i try to fix it? Will the tires last any longer?
Old Feb 26, 2005
ACURAwerx's Avatar
robb i looked at your pictures
Old Feb 26, 2005
ACURAwerx's Avatar
even if they didn't adjust it the best possible, did they adjust it a lot from the way it was before? did i need alignment?
Old Feb 26, 2005
robbclark1's Avatar
Well I am running close to -2 camber in the front and -.8 in the rear. As long as you rotate your tires every 2-3 months you should be good. You will probably see some wear but you aren't that far out of spec. I just hate it when the stupid guys don't know what the fvck they are doing. Obviously the camber kit isn't a stock camber kit and they know that but they dont know what the fvck to do with it. That is why I suggest a race alignment shop. YOu can always change it to add less camber and then bring it back to them for minor tweaks, if they don't know what to do. It isn't that hard to do your own alignment but it should be tweaked for more accurate specs by a shop.
Old Feb 26, 2005
robbclark1's Avatar
Not really. They changed some of the toe, but it wasn't anything to worry about. They actually didn't change that much at all. Where is says BEFORE is what it was on the rack before the made adjustments. Where is says ACTUAL is what it was after they were done. Anything RED is outside of spec, and anything GREEN is inside specs. You can see they didn't do ****.
Old Feb 26, 2005
ACURAwerx's Avatar
how do you do alignment yourself!
Old Feb 26, 2005
ACURAwerx's Avatar
and i have directional tires, so does it make a difference rotating them front to back every 3 months?
Old Feb 26, 2005
nitroal1973's Avatar
Broken Road......
nitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to all
That printout is off of a Hunter machine....anyway, the alignment guy doesn't show **** if thats what you got. You don't have to go to a race shop, but find a shop that knows what they are doing. My main alignment guy is excellent, the best I have ever worked around. We do a lot of custom stuff for the hot rodders around here. What is this shop?? A reputable shop, or a Sears kinda shop??
I think you got hosed....
Old Feb 26, 2005
robbclark1's Avatar
I do it
Your camber up front is only -.4 and rear is -1.5, so yes it will make a difference.
There are a few methods, one being the string method. The other is just counting the number of turns or just eyeballing it. Like I said, you can make large movements to push the rear camber from -1.5 to say around -.8 by eyeballing it and then have them do the small adjustments. I would bitch them out and have them give you another alignment for free.
Old Feb 26, 2005
ACURAwerx's Avatar
national tire and battery, should i go back and tell them to do it again?
Old Feb 28, 2005
Broken Road......
^^ So, basically Sears......you could either make them do it again, or take it to a reputable shop, pay them to do it, then take both print outs back to NTB and tell them you want a refund...that's probably what I would do.
Old Feb 28, 2005
ACURAwerx's Avatar
robbclark said its not a big deal and it won't really make a difference..
so if that is the case i'll just keep the alignment the way it is and never go back there
Old Feb 28, 2005
ACURAwerx's Avatar
do places that are just alignment places do better jobs then a sears or ntb?
Old Mar 7, 2005
robo1040's Avatar
Once you go Black on Black, You Never Go Back.
robo1040 will become famous soon enough
dude i do alignments for pep boys, and ill tell you if anything comes in that is lowered or has any suspension mods, we usually kick it out the door. alignments only pay the guy who is doing it a hour of labor time, basically, doing a alignment on a lowered car is gonna take longer then that to get it done right, hense, a regular tech like me dosent want to spend 2 hours on your car if it only pays me one hour, see the dilemma. basically, take it to someone and tell them you are willing to pay the cost to get it dont right, if you want it done right
Old Mar 7, 2005
Deception2k1civic's Avatar
My car is goin to have a new look!!!
Deception2k1civic has a spectacular aura aboutDeception2k1civic has a spectacular aura aboutDeception2k1civic has a spectacular aura about
i also do alignments. the way that your printout looks, it seems they adjusted toe on front and rear. and it looks like they used a hunter machine. the machine tells the tech that there isnt any rear camber so they probobly didnt bother to look and just did you toe. i can do a civic with front and rear camber kits in about 30 min if everything moves easily.
Old Mar 8, 2005
VNlilMAN's Avatar
The Standard One
take it back.. its pretty clear to me they didnt even touch the camber...
him telling you you need additional parts and you saying that you do and him saying oh well we already adjusted it as far as we could should have already told you that he's sh*tting you..
^run on sentence but eh, sue me...
Old Mar 8, 2005
Broken Road......
We do alignments on all kinds of lifted and lowered stuff, and most are no different if the people who did the lift or lower know what they are doing. We will get it as close as whatever adjustments allow us to. Very rarely does it take any longer than a stock vehicle.
Old Mar 8, 2005
VNlilMAN's Avatar
The Standard One
i need to take my car to your shop... the shops down here suck a$$ or charge too much.
only if i was in norcal...
Old Mar 8, 2005
Broken Road......
^^^^ find a Tirepros dealer in your area.....
http://www.tirepros.com/locator.asp
Old Mar 8, 2005
ACURAwerx's Avatar
the guy told me that it takes 30 minutes to "set up" the car on the machine and only 5 actual minutes to do it! How many miles will my tires last with this alignment if i rotate them every 3 months... and how many will they last if i get it redone and its done right? If its not going to make a big diffrence i'm not going to bother with it!
Old Mar 9, 2005
VNlilMAN's Avatar
The Standard One
the thing is, you paid for it to be done RIGHT.
but eh it really shouldnt be that big of a deal. its just camber and it isnt off by a whole lot since -1.5 is spec. you can always flip the tires around so that the good side now starts wearing out.
Old Mar 9, 2005
ACURAwerx's Avatar
i have directional tires.. so i can't flip them on the other side of the car
Old Mar 9, 2005
robbclark1's Avatar
Just get it done...then you don't have to worry about rotating. I order you to get it done again and stop being indecisive hahaha
Old Mar 9, 2005
ACURAwerx's Avatar
FINE, i'm going to get it done
Old Mar 9, 2005
VNlilMAN's Avatar
The Standard One
eh i do too, thats why i had to dismount/mount them again. Paid $10 a wheel for it... So i guess in a sense, its just worth it to take it back to them
