alignment question
Originally Posted by ACURAwerx
the guy told me that it takes 30 minutes to "set up" the car on the machine and only 5 actual minutes to do it! How many miles will my tires last with this alignment if i rotate them every 3 months... and how many will they last if i get it redone and its done right? If its not going to make a big diffrence i'm not going to bother with it!
Originally Posted by VNlilMAN
eh i do too, thats why i had to dismount/mount them again. Paid $10 a wheel for it... So i guess in a sense, its just worth it to take it back to them
does it matter what machine they use for the alignment? or is it all about the technician?
the tire shop said that you can't flip a non directional tire to the other side.. is this not true? what do you do exactly when you do a alignment? Does it take a lot of skill? I always thought it should be easy
Technicians make sure your wheels are aligned. They check camber, caster and toe and set them within specs. ****, I can do it if I had a machine.
Dude, i lowered my civic 2.5", and got an spc camber kit and did it myself. I was a technician for chevy and that alignment (your attachment) was negligable. I first took my car to get aligned at the place i worked at, and it made it worse in the rear, the front was fine, I physically had to align my tires with my eyes. Since i've done that i have not had any tire wear to either side. If you try do do it yourself beware of dogtracking if you mess around with the rear.
Originally Posted by robbclark1
Directional tires can go on the other side, but they aren't supposed to. It won't kill them.
, Think its an "H" Joined: Nov 2003
Hey i just went to get my car aligned.. all 4 wheels. It's been a year, and i'm sure my car is out of alignment. So i drop my car off and come back in about 20 minutes.. and to my surprise the car is sitting outside. The guy told me it would take an hour ! by the way.. my car is lowered on neuspeed race springs. So i pay for it and he tells me.. well your car isn't aligned all the way.. "you need a camber kit to do that" then i said.. I HAVE A CAMBER KIT! Then he says..o well you can only adjust one so much. blah blah blah.. He told me to try to get "additional parts" for my camber kit and all this other bs. I have ingalls camberkit and the people that installed it said its the best quality you can get. My question is.. is it true that you can't get accurate alignment with a lowered car? the guy said the tires will still wear weird and stuff.. and i'm just like , why am i paying for alignment when my tires won't be aligned? I thought that was the whole purpose of the camber kit. the people who aligned my car last year didn't say anything about it. There is a copy of my alignment paper on the attachments, can someone who knows about alignment tell me if they were telling me the truth. I have a feeling that they didn't adjust my camber kit or something cuz they said i didn't have one. thanks guys
Heh, i just looked at the print out of your car. Oddly enough they also measured SAI, If you look close you will see the SAI is lower on the right side and also caster is a bit low compared to the left side. Caster is still in spec but there is a difference from right to left . That being said, JUST a shot in the dark but i bet the right lower control arm is bent ever so slightly. Granted its only .2 of a degree of camber and .6 of caster.
^^ whats caster, toe, camber... I understand when ur wheels aren't aligned you get camber wear, but i don't understand what all these things mean... is .2 degree of camber and .6 of caster good or bad?
) Camber/Caster/Toe
Camber, caster, and toe are all changes to the way your wheels and tires come in contact with the ground. Most factory cars have some negative camber in the rear set. Most owners’ manuals will tell you OEM specs of camber, caster and toe. These settings can become moved by driving, hit potholes, racing, etc. This is why you get an alignment every so often. Alignment shops will return your car to factory or near factory settings.
They affect vehicle dynamics greatly if fine-tuned. Each car is different so you will have to play with the sittings to get the desired results. General rule of thumb is that some negative camber and some toe out will help handling, but the amounts will vary. So please don’t think that leaving your tires at –2 degrees camber all the time will help you! By changing the camber, caster and toe, you WILL ruin your tires faster. They take more stress and take the corners harder so it is suggested that you don’t run with “race” settings on the street if you can prevent it. You will be buying tires every month. Parts like Camber or caster plates allow for quick changing of the camber or caster for race days.
Links
http://www.artsautomotive.com/thealignmentstory.htm
http://www.ozebiz.com.au/racetech/theory/align.html
http://corvettesuspension.com/cambercastortoe.htm
http://www.stockcarracing.com/tipstricks/31519/
Read the Autox FAQ. Google is your friend....
tfnaafLet me put the Hunter on my front porch. I am sure the home owner's association would love that!
Links
COOL! I'm going to take my car back today to the same place.. (i don't have any money to get it redone).. Should all the numbers be in spec if its done right? Or what should i look for? I don't want to get it done, then bring it back and all that.
Originally Posted by nitroal1973
^^ So, basically Sears......you could either make them do it again, or take it to a reputable shop, pay them to do it, then take both print outs back to NTB and tell them you want a refund...that's probably what I would do.
BTW When you installed your front camber bolt, you did put it on the top mount bolt right?
OK, Sears doesn't own NTB anymore, but about the same time of techs/quality of work. Our rack is a new Hunter scissor lift, and it is flush mounted in a pit, so it is level with the floor. We did this specifically for some of the lowered stuff we see.
No number "current" number should be red. Sit there and watch them do the alignment and watch the screen. If you feel they are doing it wrong then tell them. I mean you did pay for the service, you should tell them how you want it. It really isn't that hard to get into spec.
The Standard One
Originally Posted by c kim
I was wondering if most alignment shops know how to adjust the camber kits on our cars? Or should you go to certain shops that are more credited?
i brought my car back.. is it true that you have to take apart ingalls camber kit to adjust it? I told them that most people with 7thgens have ingalls or spc camber kit (don't know if that is true or not, but i think it is).. and they said that maybe in import tuner that is true but they aren't good camber kits.. and you can't adjust them unless u take them apart first. is this true? However, i think the camber kit was adjusted to maximum when it was installed, however i am not sure. So, if my camber kit can't be adjusted, then did i buy one for nothing? but i think its adjusted all the way already. He said the most popular camber kits are called "aim" or something.. however when i looked most people only offered ingalls and spc for our car. so i dont know about that. Furthermore.. they said they couldn't adjust the camber on my rear because the tires (205/50/15) will hit the fender if i have a lot of weight in the back or hit a bump.. which is true, because they showed me everything. They also adjusted the front more.. he said lowered cars have their own alignment specs , and not the same as stock spec. The guy explained everything to me for a long time and let me watch him to do the alignment .. ill post the new sheet when i get home! tell me what u guys think
The Standard One
why do lowered cars have different specs? I never got that...
NO you do NOT have to take it apart in order to adjust them.
You just loosen the two nuts, turn the big middle thing untill your at the desire camber and tighten the two nuts again..
He is a dumbass. Take it to someone better.
Again, the only issue I can see is if you installed the camber kit at max. Both arms should have only been set at half way when put on the car.
Just read this:
http://www.7thgencivic.com/forums/sh...d.php?t=201704
Lowered and lifted cars and trucks dont have " different specs " But they sometimes need to have the spec altered for better tire wear...
Examples:
You know the idiots that put the 13" wheels on thier civics that stick out 6" beyond thier fenders? Well if this car is aligned to factory specs it will eat tires like wont believe. Same goes if you use a severly altered tire diameter, as in lots taller or lots shorter. Both of these 2 situations are effecting scrub radius and this CAN cause sever tire wear. Adjusting a cars spec to a different spec other than stock is an ART, and care should be taken when doing so.
Examples:
and i believe my camber kit was installed at max.. i think the guy said like.. he wans't sure how much to adjust it so he just put it on max, but i'm not sure
