KYB Install Issues on an '03
Old Feb 20, 2005
Tearstone's Avatar
Tearstone is an unknown quantity at this point
I'm not 100% familiar on the different trims of the Civic models, but I believe this particular guy's car that I worked on was had an LX.
So he came to me with KYB AGX Struts + Eibach Sportline springs. Upon installation I had a problem with inserting the bolts through the front struts of the car. I pulled the strut assembly back out of the car and found out that the KYB holes were 2mm too small, where the stock struts were 16mm. Unfortunately, I don't have a drill bit that big, also I was a little concerned about the structural integrity of the strut itself as well but these are the pictures.
Stock Struts
KYB AGX Struts
Side by side comparision
Is this just a fluke or something that is well known per a year-to-year difference of the 7G?
Otherwise, the rest of the install went great minus that, I used the stock struts and put the KYBs in the rear with the Sportlines all the way around.
Noticable differences between this car and my 3G Eclipse was that I was not too hip on having to go through the trunk & the back seats just to remove the rear shock assemblys, but it's similar to a lot of other imports though. Another odd difference was that the tie rods were connected to the struts which I thought was a little odd as well and definitely use a ball joint puller for those.
Old Feb 20, 2005
flotsamm's Avatar
Looks like theyre made for the 2001-2002 struts which are 14mm instead of 16mm. Same thing with Tokico's. Not sure if KYB makes 2003+ struts, but if so then you need to exchange them or drill them larger like some people have done with their Tokico's. Probably better to call KYB first. I dont know if making the holes larger would affect the strength enough to make them unsafe.
Old Feb 20, 2005
Tearstone's Avatar
Excellent information, I'll pass it along! Thank you
Old Feb 20, 2005
anibal's Avatar
anibal is an unknown quantity at this point
If I'm not mistaken it should be the other way, 2001 strut bolts are 16 mm while newer are 14 mm.
Old Feb 20, 2005
shmik1's Avatar
no, newer is bigger because mine were for 01-02 and we had to drill them.. (mine is 03)
i've had no probs and we DIY'd mine about 4 months ago or more...
this was with tokicos, not KYB..
oh yea and btw.. this is a known issue w/ 01-02 vs 03+
Old Feb 20, 2005
dvsdara's Avatar
dvsdara is an unknown quantity at this point
It's not really an issue like everyone has posted. You'll need to drill the bolt holes for it to fit. I mechanic used this drill it that went from small to big and he said the end point on it was about 11/16. So that's how big you'll need to drill the hole for it to fit.
Old Feb 20, 2005
shmik1's Avatar
it is an issue if ur wanting to use 01-02 on an 03.
Old Feb 20, 2005
Xenin's Avatar
Superior Evolutionary Element Destined-factor
Xenin is an unknown quantity at this point
KYB and Tokico dont make 03+ struts. drilling them might void the warranty.
Old Feb 20, 2005
civicvtec1ps's Avatar
Search and Learn
Yea, KYB agx's specially made for 01-02 model being 14mm knukcle bolts.
Couple guys from clubrsx also tried to fit those on thier cars and they had to enlarge hole to 16mm from 14mm.
No big deal.
Old Feb 21, 2005
Tearstone's Avatar
I would like to have drilled the holes bigger myself, but we could not find a drill bit the right size at home depot. The closest we could find did 15.88mm. Regardless, that's something KYB really needs to address (and Tokico apparently).
Old Feb 21, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
I know no one has tried it, but maybe someone should. The simplest solution to this problem would be to just make bushings for the knuckle and convert the 03-05s to 14mm crash bolts. Clearly they can handle the force or they wouldn't have put them in the 01-02s, so I don't see the problem. Make a steel bushing with a 1mm wall thickness and slip it in the knuckle. Put 14mm crash bolts in and call it a day. Why can't Tokico and KYB think of this?
Old Feb 21, 2005
DaddyFatSacks's Avatar
DaddyFatSacks is an unknown quantity at this point
I didnt even know KYB had struts, how much are they?
Old Feb 22, 2005
Jeff B's Avatar
Jeff B has a little shameless behaviour in the past
Post
Yeah the KYB AGX's are about 400-450 online for a set. Prob the next best thing to Koni's. I am getting a set myself in a few weeks...
Youshoe
May 22, 2015 09:36 PM
pincookie1
May 4, 2015 12:22 PM
Thees1
Apr 14, 2015 08:23 AM
briaros6
Dec 10, 2001 06:29 AM
Elusiv1
Nov 8, 2001 09:55 PM
