Camber/Caster Plates!!!!!
Old Feb 4, 2005
Zzyzx's Avatar
Autocross Junky
Finally some one makes a camber/caster plate for our car....
$370.. Cheeper then Hotchkiss, More expensive then Tein, but its the only one that allows you to adjust Caster too.
http://www.k-mac.com.au/makes/honda.htm
Old Feb 4, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
I think I should be excited.... problem is they're $370. Damn. Thats just a ****-ton of money. Oh well... I'll just adjust my camber and live with it.
Old Feb 4, 2005
Zzyzx's Avatar
Autocross Junky
I just shot off an email to see what the adjustment range is on them.
Old Feb 4, 2005
PunkingCivic's Avatar
I need TP for my bunghole
linky no worky
Old Feb 4, 2005
Zzyzx's Avatar
Autocross Junky
Originally Posted by PunkingCivic
linky no worky
Works for me...
Old Feb 4, 2005
is there a picture you can post?
Old Feb 4, 2005
Zzyzx's Avatar
Autocross Junky
Small one...
Old Feb 4, 2005
now the damn site came up.
Old Feb 4, 2005
robbclark1's Avatar
Retired suspension supermod.
How can we adjust caster with the control arm we have?
Old Feb 4, 2005
Zzyzx's Avatar
Autocross Junky
The control arm is attached to the Knuckle through a ball joint. so the knuckle and strut will shift and the ball joint will compensate.
Old Feb 4, 2005
peteriap's Avatar
peteriap will become famous soon enoughpeteriap will become famous soon enough
Guys, be careful with that company. We have tried to business with them for a while on BMW kits becuase they are one of the few that manufacture a ton of BMW kits. However, they are extremely slow at responding. This may be due to them being in Austrailia. Just a heads up.
Old Feb 4, 2005
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
thats wayy too much!
Old Feb 4, 2005
Zzyzx's Avatar
Autocross Junky
Interesting... But if they are the only ones with a Camber/Caster kit... I may have to take my chances.
Old Feb 6, 2005
skipbarber's Avatar
what is factory caster set to? to me the front suspension seems to sit completely vertical.
Old Feb 6, 2005
Jap-Euro Fusion
Factory caster is around 2 degrees laid back... I think its negative, but I don't remember which way the caster sign convention works.
Old Feb 6, 2005
CrazyCakes's Avatar
CrazyCakes is an unknown quantity at this point
yeah it's like 1.5 to 2 degrees (which is like none). adjusting camber and caster might be cool but i also wonder what the adjustment range is.
Old Feb 6, 2005
streetglower's Avatar
why would you need to adjust the caster anyway? From what I know caster doesnt affect tire wear anyway.
Old Feb 6, 2005
UTICivic's Avatar
UTICivic will become famous soon enoughUTICivic will become famous soon enough
^You my friend need to take Phase 8.
Old Feb 6, 2005
robbclark1's Avatar
From Mike Kojima
Positive front caster Helps both stability, steady state cornering and turn in because the suspension will get more negative camber when the wheel is turned/ 6-7 degrees positive, negative caster is not useable
Can increase understeer, especially in cars with wide, low profile tires due to a non linear increase in corner weight. Increases steering effort, SE-R’s are not easily modified to make this adjustable, FWD cars can see an increase of torque steer with excessive positive caster
Another web page
The caster angle is a key suspension factor that will contribute to a vehicle's handling. This angle is the measurement between the tires' vertical centerline and the centerline of the steering axis through the upper and lower ball joints. This angle is altered by tilting the steering knuckle pivot points backward or forward.
Positive caster settings provide a greater degree of steering effort, self-centering and stability to the vehicle Therefore nearly every car has a positive caster setting. A lot of caster gives you greater stability in high-speed, straight-ahead driving, but at low speeds, steering is heavy. A smaller positive caster setting makes for easier tow-speed steering, but at high speeds, the vehicle will tend to wander.
The best caster setting is usually the maximum positive setting recommended by the manufacturer. Caster settings will normally range from +2 to +6 degrees. When setting the caster, the sides of the vehicle should be within 1/2 degree of each other.
Old Feb 6, 2005
already tooken phase 8. It was AC and heating. You mean 28. Yes I already took that too. But I guess our teacher sucked. We got into alignments and what not, but our teacher went by that crap too fast.
Old Feb 7, 2005
Zzyzx's Avatar
Autocross Junky
got an Email back from them...
Does not effect top of strut clearence.
Range of extra Positive or Negative Camber is
2 degrees and Positive Caster is extra 1.05 degrees.
.. I may have to get these.
Old Feb 7, 2005
P40vic's Avatar
P40vic is an unknown quantity at this point
Are these intended for stock diameter springs or only reduced diameter ie coilovers? If they fit stock diameter, they sure would be the only game...
Old Feb 7, 2005
Zzyzx's Avatar
Autocross Junky
According to them, it only replaces the upper mount. SO they should work with stock sized springs.
Michael Durkin
Transmission
Sep 24, 2015 12:35 PM
