KYB AGX Review
Old Feb 4, 2005
nitroal1973's Avatar
Broken Road......
nitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to all
Thumbs up KYB AGX Review
Installed the Eibach Pro Kit, KYB AGX Struts yesterday. HUGE improvement in the ride and handling of the car. Struts are currently set on 2, so I'll have to play with the numbers to see how much of a difference the settings actually make. Based just on 2 days driving, I am extremely pleased.
Old Feb 4, 2005
Zzyzx's Avatar
Autocross Junky
Little hint on tuning .... KYB's adjust low to mid speed rebound dampering, so they are designed to influence handling more then they influence ride quality....
Basic idea here, Increase the rebound dampering on the opposite end of the car that you want to have stick more. I.e. if the car is understeering, either increase Rebound dampering on the rear, or decrease it on the front. If the car is oversteering, Increase rebound on the front and/or decrease it on the rear. Simple.
otherwise Increasing rebound on the front can help make the car more responsive, but you have to balance the Responsivness Vs more understeer side of increased rebound on the front...
Happy Tuning!
BTW: I have konis, and they adjust Low Speed rebound too. On the street I have the front set to full soft, and the rear set to 1/2 Up from full soft. when I autocross, the fronts stay at full soft, and the rears are set to 1/2 Turn down from full had, then adjusted as the track needs.
Old Feb 4, 2005
Broken Road......
^^ Thanks!!!
Old Feb 4, 2005
Zzyzx's Avatar
Autocross Junky
no prob, Your probably going to end up with a stiffer setting on the rear then the front.
welcom to the often misunderstood art of tuning dampers...
Old Feb 4, 2005
Liro's Avatar
Back from the dead
same goes for increasing the ridigity of the frame....if you are looking for more oversteer add sway bars to the rear....
Old Feb 4, 2005
Zzyzx's Avatar
Autocross Junky
^^Sway bars dont reinforce the frame.... they increase roll resistance by tieing the two sides of the suspension together. THus influencing the balance of the car. (The side of the car with more roll resistance will tend to lose traction 1st... So, if the car understeers you either decrease roll resistance at the front, or increase it at the rear ) Which explains why I'm running a 15.9mm front anti-roll bar and a 25.4mm rear...
Old Feb 4, 2005
flipbagz's Avatar
Go Pistons!
flipbagz is an unknown quantity at this point
where did you get your kyb's?
Old Feb 4, 2005
Shifty's Avatar
will the agx's work with ground control coilovers? I mean for longevity of the agx's.....im planning to autocross this summer and i was wondering the longevity of the agx would be, anybody?
Old Feb 5, 2005
Broken Road......
Our shop signed up as a KYB authorized installer, and included in the deal was a free set of struts, so I managed to score them for my Civ!!
Old Feb 5, 2005
Broken Road......
I am going to take some of your knowledge here, and stiffen the rears up and see what happens. Also going to add the Eibach anti-roll kit and Neuspeed front lower x-brace. How does this sound?? I don't autocross, but like my car to stick to the road, and go where I want it, when I want it. I do appreciate your help here!! Rep point to ya!!
solarpunk70
Apr 12, 2016 11:43 AM
Zygrene
Mar 22, 2016 12:36 PM
OptimisticWay
Sep 18, 2015 09:37 PM
Bikergofast
Sep 12, 2015 01:36 PM
bmwstar98
Aug 16, 2015 02:28 PM
