koni yellows are crap(rears)
Old Jan 22, 2005
CrewChief's Avatar
Remebers the old days
CrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of light
Thumbs down koni yellows are crap(rears)
I have had my yellows on for about 9 months not and when I first put them on I had my doughts about the rear being held up by a lock ring. well my fears have been proven. I was driving and hit a pot hole. it wasn't even that hard and the entire right rear side of my car just hit the ground. the tire was completely tucked in the well. the ring had popped and the perch slid to the botom of the strut. car was dragging on the ground. I had to fix it on the side of the road with some hose clams just to get home. Now I am saving up for a set of full coilovers. for now I have 4 hose clamps holding the perch up. I can't belive they would put all that weight on a cheap little snap ring. That was a very stupid Idea. Just figured I would warn everybody that has them. it could happen to you.
Old Jan 22, 2005
MrWong's Avatar
Bushido
MrWong is an unknown quantity at this point
Are you sure it was installed properly?
Old Jan 22, 2005
CrewChief's Avatar
yes I installed them. there is an adjustable snap ring that locks in to a slot under the perch that hold the perch up. Thats it a little bendable snap ring.
Old Jan 22, 2005
streetglower's Avatar
I will ask too, are you sure you installed them right because it sounds like you didnt. I have had my konis on for over a yr. now and have had no problems whatsoever. And I know alot of other people havent had problems either.
Old Jan 22, 2005
flotsamm's Avatar
Yeah no probs here either. I know that Koni made a change to the perch so that the ring clip is now locked in by a little groove they cut into the perch. Maybe you got an old set? Call up Koni and I bet they'll send you the fixed perches and new clips. BTW, this design is over 1 years old I think.. maybe more.
Old Jan 22, 2005
2K1Civic17"Gabe's Avatar
yeah, if you have a busted set, or the first set or whatnot, I would call them and see if they can pay for any other damage as well. Lawyer call them? i would not be paying for it myself, when they sell something like that. It was their products fault. Hope they dont have a ToS. they probably do though
Old Jan 22, 2005
Zzyzx's Avatar
Autocross Junky
Koni makes some of the best shocks avalible and they have a lifetime limited warenty... if some thing brakes they will most likely repair or replace it. Give them a call and see. They are one of the few companys that stand behind their products.
KONI North America
1961 International Way • Hebron • KY • 41048
Telephone: (859) 586-4100 • Fax859) 334-3340
http://www.koni-na.com/contact.html
Old Jan 22, 2005
skipbarber's Avatar
never had a problem with mine...but i see this happening occasionally. Usually user error...
Old Jan 23, 2005
Unleaded's Avatar
Unleaded is an unknown quantity at this point
well, looks like the problem is that you're on ground control wannabe coilovers. i don't think koni recommends you use sleeve coilovers (someone correct me on this). i remember someone else had the same thing happened to the rear and he was either using ground controls or skunk coilovers. i have my koni's with goldline springs for a year and i have no complaints.
Old Jan 23, 2005
flotsamm's Avatar
I wanna say it okay to use coilovers as long as you get the proper perches. Someone please correct me if I'm wrong also thx.
Old Jan 23, 2005
Zzyzx's Avatar
Autocross Junky
Ya, Koni has special perches for sleeved springs.
Old Jan 23, 2005
dirtySAMURAI's Avatar
I log in from time to time
i had gc with koni's in the rear. i hit a pothole and bent the shock...
Old Jan 23, 2005
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
I've had koni yellows for over 2 years in the rears with no problems whatsoever.
Old Jan 23, 2005
goodtimes's Avatar
Dam when did that happen after we left
Old Jan 23, 2005
CrewChief's Avatar
no before you got there. like a day before. just forgot to bring it up.
Old Jan 24, 2005
djmota's Avatar
You are correct and you can buy these little adapters for less than 20 bux from ground control They encompass the lock ring and slip inside the sleeven
I have been running gc's with koni's for 2 1/2 years no problems.
They will look like this with the adapters.
Koni will send you some new lock rings free. Then get the adapters from gc.
Old Jan 24, 2005
PICHY's Avatar
ALGARETE
get me the place so i can order the adaptors.....mine dont look like that....my coilovers sit on a plate almost @ the bottom of the strut...but so far no problems....i dont want it to turn into one... i had mine for 2.5 years
Old Jan 24, 2005
2slowcivic's Avatar
2slowcivic is an unknown quantity at this point
I agree koni's suck but they don't come apart
I beat the hell out of my ep3 auto xing and hittin potholes
and stuff there's something wrong with the way you
installed those rings
Old Jan 25, 2005
something is wrong with you if you think konis suck. I think konis are some damn good shocks. Either you all arent installing them properly, or put on the wrong size or something.
Old Jan 25, 2005
djmota's Avatar
ground control link
Just call em up and tell them what you need.
Old Jan 25, 2005
CrewChief's Avatar
Ok. my wife ordered the ground control sleeved coilovers for me a long time ago. she ordered the ones for stock shocks cause thats what I had at the time. I guess that might have something to with it. so warning to those running that set up as well.
Old Jan 29, 2005
qkmike's Avatar
qkmike is an unknown quantity at this point
i had the same problem too, both c-ring broke. And there is an adpter for it, very cheap too.
juror
Suspension DIY
Jul 30, 2019 03:28 AM
GotSiR
Jun 23, 2016 04:06 PM
JohnnyBxo
Nov 12, 2015 03:04 PM
Curtchuk
Aug 5, 2015 02:14 PM
TheRubixHorse
Jul 29, 2015 05:22 AM
