Quick Question about koni fitment
Old Jan 16, 2005
SaRno03Vic's Avatar
** ThE SeAsOn VeT **
SaRno03Vic is an unknown quantity at this point
Im trying to buy front koni's off a member...im not sure it he is just selling the inserts or the entire assembly....will eithier fit on my car i have an 03 and i heard that the fitment w/ 03's are a lil different that the 01-02. please input would really help me
Old Jan 16, 2005
robbclark1's Avatar
Retired suspension supermod.
Konis only come in inserts. You have to measure your strut housing. Konis come in either 50 or 55mm and different civics have different shocks and Honda didn't arrange it by year.
read second post http://www.7thgencivic.com/forums/sh...d.php?t=171892
Old Jan 16, 2005
dariusld's Avatar
dariusld is an unknown quantity at this point
New Konis come in inserts. It's possiable he is selling the whole assembly.
Old Jan 16, 2005
robbclark1's Avatar
Koni's for our car only come in inserts. Unless he is selling his modified strut with the koni already inside, then it should only be an insert. Now, he could be selling it with the insert inside a stock strut, but koni doesn't sell that. If he is selling it with a modified OEM strut then it should fit any 7thgen.
Old Jan 16, 2005
flotsamm's Avatar
If he's selling you the whole strut assembly with Koni insert already installed off a 2001 or 2002, the steering knuckle(wheel hub, spindle, whateva you want to call it today) will have 14mm bolt holes rather then the 16mm holes that the 2003 models have. You'd either have to get the holes enlarged, remove the inserts and put them in your strut houisings or get the right steering knuckles. The latter is not worth it.
Old Jan 17, 2005
robbclark1's Avatar
good call! It will still fit though
Strycker
Aug 2, 2015 08:40 PM
protoCall7
Bolt-on Engine Performance
Jul 26, 2015 07:41 PM
sam31444
ECU Fried
Jul 20, 2015 08:31 AM
NoobyKid
Jul 13, 2015 07:53 AM
