Eliminating car rubbing the front tires...
Old Jan 8, 2005
Profoxcg's Avatar
Profoxcg is an unknown quantity at this point
I have a quick Q,
I have just dropped my car with ground controls, and my drivers side rubs while cornerning moderate due to body roll. Which is normal, but for example, I rolled the fenders in the rear to aliviate that problem, however what can I do to the front?
do you guys remove the liners? I have 215/45/17... what do the guys with the 18's and 19's do? - I want my car to be tucked a little bit
Thanks
Old Jan 8, 2005
infinite's Avatar
infinite is an unknown quantity at this point
i got 18's and a 1.75" drop in the front. i'm running 215/40/18 tires and the front is almost tucked. i don't rub at all, or maybe i never noticed if i did. can you feel it rubbing while you're inside the car or is there a loud noise when it does rub?
Old Jan 8, 2005
Profoxcg's Avatar
both...
Old Jan 9, 2005
jttegx's Avatar
OMNES AD UNUM
how low are you dropped on the GCs? i had 215/45/17 and had coilovers with rubbing problems on all 4's. , had to raise it so when body flex occurs, the front wheel doesnt rub against the fender wells. as for the rears, had to adjust the rear camber kit so it sits a little negative.
solutions:
1) raise the car so you have at LEAST half finger gap between tire and fender.
2) if you dont have aftermarket shocks, it may help body flex with its stiffer design then the stock shocks
3) strut bars
4) different tire size (205/45/17 or 215/40/17) theirs others to choose depending on what you really want.
Old Jan 9, 2005
01civick20nme's Avatar
01civick20nme is an unknown quantity at this point
my wheels are tucked and i have 205/40/17 and i have no problem it looks great
Old Jan 9, 2005
i have the front gc's lowered all the way down btw
Old Jan 11, 2005
bloodhound248's Avatar
bloodhound248 is an unknown quantity at this point
anybody know what the maxium drop you can have with the 215/45/17's without rubbing? thanks
Old Jan 11, 2005
Profoxcg's Avatar
I had 2" with eibach sportlines... no rub at all on 4 corners. Although the front sat a little high for my linking (1.7 finger gap)
Old Jan 11, 2005
VNlilMAN's Avatar
The Standard One
I used to rub with my 215-40-18s on d2 coilovers. I remember everytime i turned the wheel all the way it would make this horrible noise. I was too lazy to raise it so I just stopped turning the wheel all the way =p.
One thing that helped slightly though was tucking in the liner(instead of removing it). I had to take off a clip or two but it worked and didnt make that noise as often... Pretty much the best thing to do is just raise it untill it doesnt rub anymore.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
bsmiley
Apr 27, 2015 01:27 PM
Ian SFBA
Interior DIY
Apr 25, 2015 02:25 PM
Fastfebur
Apr 22, 2015 01:37 PM
GH04si
Apr 15, 2015 08:13 PM
