KW Coilovers
I am quite happy with mine. They ride VERY hard, but the handling is unreal. I haven't had a chance to go to the track with them properly setup and good tires. I can't wait until spring (snow here, riding on winter tires now) when I get new tires.
7thgen Power Maker
Originally Posted by standalj
Ride very hard? From what I have been told, the KWs are much better than TEINs for both street (in terms of ride quality) and track (in terms of actual performance).
I need TP for my bunghole
For us suspension tuning dummies
is there a spring rate chart or can someone tell me:
whats the average spring rate for stock suspension?
what is a good street performance spring rate?
What spring rates should be considered track?
7thgen Power Maker
Suspension FAQ
Rep points please.
Originally Posted by dezod
Man there is so much crap in all those suspension links, no wonder people ask for a quick answer.
PS i would give you rep, but I past my limit for the past twenty four hours
Autocross Junky
YOur going at it the wrong way... by trying to brake it down in to "Street spring rates" and "race spring rates" when there really isnt any... simply becuase what spring rate you should be running, in a purely handling sence, are determined by how rough the surfaces you drive on are. Simply Put, the rougher the surfaces the softer the spring required. Both for street and Race.
Stock Rates woudl be in the Low to Sub 200 LB/in Probably front and rear for the non Si civics. The RSX suposidly has 207 LB/IN Front and Progressive rate rears (326-415 LB/in)
That will work! Thanks!
Autocross Junky
^^ thats in KG/cm rather then LB/IN....
LB/in can be found here
http://www.7thgencivic.com/forums/fa...aq_susp_faq_q1
beanhead
Sep 24, 2015 12:04 PM
