front sway bar making pinging noise
Old Dec 21, 2004
ricergribbs's Avatar
ricergribbs is an unknown quantity at this point
ok so i installed my progress front sway bar. everything is tightened down and nothings wobblings/moving. yet whenever i drive and take a left hand turn, i hear this pinging noise coming from the left side. any ideas?
Old Dec 21, 2004
Roy's Avatar
Roy
Roy is an unknown quantity at this point
make sure the end links both to the sway bar and to the control arms are properly torqued down to the right specs which is 80 or 115lbs.?? don't quote me on that.
Old Dec 21, 2004
how can i check to make sure they are torqued down to those specs? u need to hold it with an allen wrench while u tighten the nut on. i just got under the car to make sure the bolts underneath were tight, and they still are so cant be those.
Old Dec 21, 2004
ok well i just checked the endlinks for the third time. they are sitting tight and definetly not moving anywhere. so im out of ideas.
Old Dec 21, 2004
Zzyzx's Avatar
Autocross Junky
It could be rubbing on the exaust durring cornering...
Old Dec 21, 2004
nop, no chance of that. i have an LX so i dont have the catalytic converter. theres prolly 4 inches of clearance betwee the exhaust and the sway bar.
Dorval Andre
May 1, 2015 09:37 AM
bsmiley
Apr 27, 2015 01:27 PM
jessepimpride
Nov 13, 2001 05:59 PM
andylao
Nov 4, 2001 01:19 PM
JeffSpeed21
Nov 3, 2001 10:32 AM
