Do I need a spring compressor?
Old Dec 16, 2004
givemenorp's Avatar
givemenorp is an unknown quantity at this point
when installin tein coilover do i need to rent a spring compressor?
Old Dec 16, 2004
civic_kyd's Avatar
civic_kyd is an unknown quantity at this point
does it come wit everything put it together or seprate?(i have tein s.tech springs) if it does come in seprate then yes u need spring compressor. if not then alot more easier.
Old Dec 16, 2004
Mr.Modify's Avatar
nah you don't need one...ii you really don't need one with sleeved coilvers or springs.....just use your foot
Old Dec 16, 2004
2k2redcivic's Avatar
2k2redcivic has a spectacular aura about2k2redcivic has a spectacular aura about
^^^^ what he said its easy
Old Dec 16, 2004
robbclark1's Avatar
Retired suspension supermod.
you need 4, one for each coilover....
No you don't need one...
Old Dec 16, 2004
givemenorp's Avatar
so i dont need to compress the spring before i put on the 01 bearing and upper mount? It seems kinda loose ( i am trying to drop it quite a bit, is that the reason it looks so loose?)
Old Dec 17, 2004
exturbo6's Avatar
when you take off the bolt that holds them on, make sure its not going towards anything....just in case it shoots off. me and my friend did my springs and it shot off a lil...just be careful
Old Dec 17, 2004
robbclark1's Avatar
There is a DIY from Mex in this forum. Use the search feature and search for the user Mex in just the suspension form. There is a little video of how he has done it.
Old Dec 17, 2004
nindoo's Avatar
Why is my vagina bleeding?
Here in Canada me and my bud borrowed this from our local harware shop "Canadian Tire", they lent it to us for free.
Old Dec 17, 2004
dirtySAMURAI's Avatar
I log in from time to time
Full coilovers shouldn't require a spring compressor, but if you're getting Tein SPRINGS (not full coilover i.e. Tein Basic, Tein Flex, Tein SS), then it is recommended you use a spring compressor, but not necessarily a "must have."
Old Dec 17, 2004
nindoo's Avatar
^^^^ yeah I've never installed coilovers so It might not be needed. But this spring compressor thing helped when I replaced my friends shocks.
Old Dec 17, 2004
exturbo6's Avatar
i never used a compressor to install mine...and they were fine...
Old Dec 21, 2004
peteriap's Avatar
peteriap will become famous soon enoughpeteriap will become famous soon enough
If you are doing a full coilover setup, you should not need a compressor. You will pull your stock setup out and replace it with the full coilovers. No need to take the factory springs off of the oem shocks.
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
beanhead
Sep 24, 2015 12:04 PM
TheRiddicles
Sep 21, 2015 01:28 AM
tavisc
Sep 15, 2015 07:46 PM
BJB
Sep 14, 2015 11:16 PM
