agh! stupid wheel hop
Old Dec 15, 2004
mradam85's Avatar
mradam85 should not be trustedmradam85 should not be trustedmradam85 should not be trusted
does everyone get crazy wheel hop like i do?
if so are there any solutions?
tia
Old Dec 15, 2004
dj02's Avatar
x-brace, better tires. not launching so high in the rpms.
Old Dec 15, 2004
TeLLy's Avatar
Yes, it's an Acura EL
I think I read somewhere that a beefier front sway bar might also help with reducing wheel hop. Someone please confirm.
Old Dec 15, 2004
Zzyzx's Avatar
Autocross Junky
Better shocks will help out too..
Old Dec 15, 2004
djmota's Avatar
motor mount inserts will make the biggest difference.
Old Dec 15, 2004
mradam85's Avatar
Where can i get those?
Old Dec 15, 2004
dezod's Avatar
7thgen Power Maker
We can sell you stiffer shocks, or coilovers, the front sway bar......Lemme know
Old Dec 16, 2004
mradam85's Avatar
well i'm sort of broke right now, whats the first single upgrade i should do?
Old Dec 16, 2004
Zzyzx's Avatar
Autocross Junky
Shocks.... Serioulsly. the car will handle better on performance dampers with Stock springs then it will with performance springs on stock dampers..
Old Dec 16, 2004
SIinthesky's Avatar
SIinthesky will become famous soon enoughSIinthesky will become famous soon enough
Get an LSD. It will take all the shock out of that side of your car. Put the power to the ground more effectively.
Old Dec 16, 2004
Pete W.'s Avatar
Pete W. is an unknown quantity at this point
So where can I get a set of motor mounts?
Old Dec 16, 2004
bgoetz's Avatar
bgoetz is an unknown quantity at this point
Summit racing has the energy suspension motor mount inserts for our cars, you may have to call and ask for them though. They cost $35 and are the best mod for our cars given the cost they will elliminate wheel hop. the front one is simple to install but the back one may take an hour or two. The only downside is that they create alot more vibration throughout the car especially if the heater or AC is on.
Old Dec 17, 2004
dj02's Avatar
this would be nice. dont think they make one for our car tho. would be nice.
http://www.honda-tech.com/zerothread?id=1038306&page=1
Old Dec 17, 2004
sw388integra's Avatar
bigger front sway and some shocks
Old Dec 17, 2004
CuRiOuSfIsH's Avatar
Back From The Banned!
Rob at robearracing.com used to have the inserts... cant find them, maybe PM him about it.... they were inexpensive too.... I think a few members on here have/had them and they said wheel hop was eliminated but the car vibrates a lot. Basically, the chassis of the car is taking in all the vibrations from the engine and not the mounts. Maybe if wheel hop is that big of a deal to you, then it just might be a worth while investment, but there are other methods like as zzyzx stated, shock/strut
Old Dec 20, 2004
mradam85's Avatar
is there a motor mount diy?
Old Dec 20, 2004
bgoetz's Avatar
not sure, but all that you need to do is remove the front and the rear mounts (one at a time) and fit the inserts in it is not that hard. The front one is easy and is only a matter of 4 bolts (three that hold it to the tranny and the one that goes through the center and attaches it to the subframe). It will then be easily removed and the inserts can be placed in and it can be reinstalled the reverse of removal. The back one is a different story it is three bolts to the tranny and the # to the subframe varies with how you get it out. Getting it out is the trick because it is a very tight area and you have to FVck with it until you get it out. Unfortunately it is just as hard to get it back in. If you are mechanically inclined it should be no problem just a bit of frustration.
pizzahutcombo
Suspension
Jul 13, 2021 09:41 PM
alaga
Feb 28, 2016 02:19 PM
violentpanda
Sep 7, 2015 11:49 AM
jnissen
Aug 9, 2015 05:34 PM
carid
Wheels and Tires
Jul 20, 2015 07:15 AM
