Struts for GC coilovers
Old Dec 12, 2004
jeffdenato's Avatar
jeffdenato is an unknown quantity at this point
I am considering putting ground controls on my 02 civic and I was wondering what kind of aftermarket struts would be a good choice,I want good ride quality,I am not as concerned about handling,but I also want to be able to SLAM the car if i want to,I dont want somthing that will limit me.So what would be a good choice for this application.Any input is appricated.Thanks
Old Dec 12, 2004
D17thgen's Avatar
D17thgen has a spectacular aura aboutD17thgen has a spectacular aura aboutD17thgen has a spectacular aura about
check out the shock/damper faq
i would guess the kyb agx or koni yellow
Old Dec 12, 2004
robbclark1's Avatar
Retired suspension supermod.
http://www.7thgencivic.com/forums/sh...d.php?t=171892
Old Dec 12, 2004
dirtySAMURAI's Avatar
I log in from time to time
koni yellows.
Old Dec 12, 2004
jeffdenato's Avatar
Ok,that faq is OK, but it doesnt tell me what I need for my specific application,I wanted to know which one of those will go the lowest while riding the best.Thanks
Old Dec 12, 2004
robbclark1's Avatar
Of course it doesn't tell you what you need for your specific application because ther is NO SPECIFIC PART FOR YOUR APPLICATION! All of them will go low, but you have to decide which ones will work the best. If you are going to choose one, choose an adjustable one, i.e. KYB AGX, Koni Yellow, or Tokico D-spec (if you can get them by themselves). I personaly would go with Koni yellow, but man...you have to decide.
Old Dec 12, 2004
jeffdenato's Avatar
All I meant was that it didnt say which of them would go the lowest.
Old Dec 13, 2004
robbclark1's Avatar
Because they aren't meant to go the lowest, they are meant to hold the car up and to turn well. I told you what I recommended, but anything too low will put too much stress on the shocks, unless you get them shortened and revalved.
Old Dec 13, 2004
VietScouty's Avatar
VietScouty is an unknown quantity at this point
How about with Tanabe DF210 lowering springs of 1.8" all around? I was thinking of just getting the front struts since most of the problems accures there more than the rear. What would you recommend?
Old Dec 13, 2004
Zzyzx's Avatar
Autocross Junky
Well, Konis are designed to work equally well at any height with in their stroke range.... However! If you bottom them out you will destroy them. So your major limiting factor here isnt if the shock can handlle being so low, but rather if you have enough suspension travle to keep the shocks from bottoming out.
Old Dec 13, 2004
jeffdenato's Avatar
I decided to go with a set of B&Gs I ordered them today, Got them for $857 shipped brand new,So I think in the long run these will just be better cost wise.
Old Dec 13, 2004
truehonda's Avatar
truehonda has a spectacular aura abouttruehonda has a spectacular aura about
Where did you get that deal?
Old Dec 13, 2004
jeffdenato's Avatar
http://www.morepowerracing.com/
Its right there on their web site,A friend of mine told me about them, he has ordered from them a couple of times before and had nothing but good things to say about them,and so far my experience with them has been very good.
Tedverseti
Apr 23, 2020 01:45 PM
SammySC
121
Apr 7, 2017 07:43 PM
skeener51
Oct 1, 2015 05:56 PM
Tedverseti
Sep 29, 2015 05:41 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
