Attention: full coilover owners
Old Nov 5, 2004
Shlomo's Avatar
Shlomo is an unknown quantity at this point
I've had my D2 coilovers on for a couple months now and have had no problems. Since it is getting colder now, my coilovers are starting to squeak. I don't mind this but the thing that i do mind is that when i'm just cruising between 0 and 40mph the front drivers side wheel well sounds like somethings rubbing. Not really metal on metal but loud enough to hear over the radio. I checked everything out and everything looks ok. Anybody have any ideas to what it is? Could it be from the cold weather? Thanks in advance?
Old Nov 5, 2004
tripledoublegs's Avatar
Euro-Spec
PM VNlilMAN
Old Nov 5, 2004
Mystic3030's Avatar
Yup, i'm an A$$hole.
Are you sure its not your breaks? There is a pin that will grind into your rotor when the pad gets low.
Old Nov 5, 2004
Pb4uGo's Avatar
Pb4uGo is an unknown quantity at this point
does the sound go away when turning left? If so, it's a wheel bearing.
Other than that it could be any number of things in the front end from brakes to alignment to worn suspension/steering components
Old Nov 5, 2004
Shlomo's Avatar
yeah i'm sure it's not my brakes, i checked that out yesterday and i had a good amount of pads left. the sound does go away when turning left or right (i believe). What would cause a wheel bearing to go?
Old Nov 6, 2004
Shlomo's Avatar
ok, so the sound went away, i don't know how but it did??? the other question i had was, do your guys coilovers squeek more now that its cold out? if so, do you know what and where to grease them up preventing this? thanks again.
Old Nov 6, 2004
CrazyCakes's Avatar
CrazyCakes is an unknown quantity at this point
yes the coilovers make way more noise when it's cold. and i had a squeek/clunking noise on the right front about 2 weeks ago, i took everything apart like 5 times and found nothing wrong. so i went to the track beat the **** out of the car and now there is no noise.
Old Nov 7, 2004
vtecd17's Avatar
Desperate Custom Swapper Speed Freak
vtecd17 is an unknown quantity at this point
one of my buddies has a 97 dsm. his wheel was squeaking when he was cruising and turning. Turned out it was a wheel bearing fault. We put it on a lift, and squeezed the bearing up and down, and guess what, water literally squirted out like a water fountain. It took care of the squeaks. But the mechanic still insisted he replace it before it really rusted out.
Old Nov 7, 2004
Shlomo's Avatar
what would cause the wheel bearing to go?
GolNat
Jul 15, 2015 03:42 PM
2k2civic
Jan 6, 2002 12:52 PM
artychris
Jan 4, 2002 08:28 AM
deception420
Dec 6, 2001 02:31 PM
duyaknow
Nov 23, 2001 07:28 PM
