22mm Rear sway?
Old Nov 2, 2004
Epion's Avatar
Epion is an unknown quantity at this point
22mm Rear sway?
I got a 22mm RSX-R rear sway bar... I'm wondering if it's too thick for 2001 coupe? Plus I lost the bushings that came with it.... would i need to install it with the RSX-R bushings? and/or can i get aftermarket bushings? also any suggestion for endlinks?
Old Nov 2, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
stock endlinks work fine, stock bushings work fine ... I have the same bar on my car right now. some say that your endlinks will break very quickly ... but I have the stock ones on right now and they've been working fine for about 6-7 weeks already ...
I think the dc5-r rear sway works GREAT!!! ... I handle about the same with this (on 195/55/15 tires w/ 15x6 Si rims) than I did with my 225/50/16 tires on 16x7.5 rims
Old Nov 2, 2004
TeLLy's Avatar
Yes, it's an Acura EL
Agreed, DC5-R rear sway kicks serious ***. Highly recommended. Be sure to reinforce with a rear lower tie bar. And I really do think aznboysfr's very lucky to have OEM endlinks last as long as he has. I recommend Grey's endlinks anyway, not just for the increased reliability and strength, but also cause they're about a million times easier to install and remove should the need arise. Have fun taking the stock endlinks off, they're a bizznotch.
Old Nov 2, 2004
nindoo's Avatar
Why is my vagina bleeding?
Zzyzx was saying that stock endlinks are fine. He was saying people with the progress bar were busting the links because of the angle they put the stock endlinks in. I got Grey's endlinks but I also have the progress bar.
Old Nov 2, 2004
HoldDaMayo's Avatar
HoldDaMayo is an unknown quantity at this point
does the 2001 have stock endlinks? I have an LX and I know mine didn't have a stock rear sway bar...
Old Nov 2, 2004
Boilermaker1's Avatar
Jap-Euro Fusion
Its me that was saying the stock endlinks are fine, and they are. They're identical to the RSX ones.
Anyways, you need the ITR bushings or something like Energy Suspension bushings to hold the sway bar on. You can't use bushings made for a 13mm bar with a 22mm one.
Old Nov 2, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
^^ yeah, my bad ... the rubber bushings are different, but the metal clip that holds the bushing on is the same
hmm ... the dc5-r endlinks aren't exactly the same as the stock civic ones ... they're a little shorter, actually. I don't know if the rsx-s endlinks are the same as the civic, but the dc5-r ones are definitely a little different (same, just shorter)
Old Nov 2, 2004
Epion's Avatar
damn.... ic... do u guys know where i can get sum DC5-R bushings for my 22mm sway bar???? It came wit my bar but i lost them in a freakish fire... hahaha.. kiddin bout the fire
Old Nov 2, 2004
TeLLy's Avatar
Well, if you can find someone selling JDM they may have or be able to order for you. If not, Energy Suspension has a set of 22mm. I'm lovin my ES bushings.
Old Nov 4, 2004
Epion's Avatar
sounds good... thanks.. for the info
Old Nov 4, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
es bushings, eh? ... are those polyurethane?
Old Nov 4, 2004
TeLLy's Avatar
Yuppers. Only drawback is having to grease them monthly, otherwise they're so noisy...but soooo responsive!
Old Nov 4, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
^^ wtf?? ... grease them monthly? ... **** that
Old Nov 4, 2004
gh0st's Avatar
TAQUITOS!!!!
i'm supposed to grease the poly sway bushings monthly? :X
Old Nov 4, 2004
Zzyzx's Avatar
Autocross Junky
grease them when they start to squeak...
Old Nov 5, 2004
Jap-Euro Fusion
Monthly? ****... more like every 4 or 5 months.
Old Nov 5, 2004
jiggerachi's Avatar
Zoom zoom
jiggerachi will become famous soon enough
Just wrap the bar with toilet paper
Old Nov 7, 2004
02ciVike's Avatar
02ciVike is an unknown quantity at this point
I am getting this bar shortly as well. It is coming with the ITR bushings. Am I fine using my stock LX endlinks?
Old Nov 7, 2004
CuRiOuSfIsH's Avatar
Back From The Banned!
^^^ youre on the border line, depeding on how you drive, it may or may not break.
Old Nov 8, 2004
TeLLy's Avatar
No joke man, I'm using a small tube of lithium every month. I should buy a grease gun with the little nipple thing so I don't have to take off the bushings everytime.
Old Nov 8, 2004
nindoo's Avatar
Why is the squeaking so bad with the aftermarket bar bushings? The stock ones don't squeek, what gives?
Old Nov 8, 2004
Zzyzx's Avatar
Autocross Junky
Its the difference between rubber and Polyurethane. Rubber (OEM) doesnt squeak, and needs no lube, but its soft and deflects while under load. Polyurethane is hard and requires lube to not be noisy, but does not deflect while under load.
juror
Suspension DIY
Jul 30, 2019 03:28 AM
GotSiR
Jun 23, 2016 04:06 PM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
redcloud
Sep 7, 2015 01:45 PM
Viczhou
Sep 2, 2015 07:55 PM
