DC5R Lower Control Arms
Old Oct 28, 2004
civictuner's Avatar
civictuner should not be trustedcivictuner should not be trustedcivictuner should not be trustedcivictuner should not be trustedcivictuner should not be trustedcivictuner should not be trusted
im wondering if the aluminum lower control arms will fit on our civics (coupe in particular) without having to do a 5 lug brembo conversion
Old Oct 28, 2004
robbclark1's Avatar
Retired suspension supermod.
yes, but they don't do much. SEARCH!!
DC5, EP3 and EM/ES all have the same chassis. Everything will fit, but in some cases you might need to do mods
http://www.7thgencivic.com/forums/sh...d.php?t=175458
http://www.7thgencivic.com/forums/sh...ht=control+arm
Old Oct 29, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
I don't think the lca's will fit
Old Oct 29, 2004
robbclark1's Avatar
They are the same chassis, and therefore, essentially the same control arm. I am about 90% sure they will fit.
Old Oct 29, 2004
Intruder's Avatar
Intruder is an unknown quantity at this point
Well I know the LCA bushings are the same between the RSX and the Civic, but the RSX's front track is 58.5" compared to the Civic's front track of 57.8". So there is a good chance that the LCA of the rsx is slightly longer than the civic's (but this could be a difference in the subframe dimension as well).
Old Oct 30, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
dc5-r aluminum lower control arms stick out farther than the dc5-s control arms ... you would need new axles/hubs/etc if you got them
the rear ones fit perfectly though ... so if you got a hold of them, you could do a rear 5 lug swap no problem ... but fronts you would need custom axles
GolNat
Jan 12, 2021 09:06 PM
muttleytm
Jul 14, 2015 05:31 PM
Fred65
Wheels and Tires
Jul 14, 2015 06:40 AM
fordover
Jul 11, 2015 09:10 PM
