after i get my car aligned!!
Old Oct 27, 2004
exturbo6's Avatar
so i took my car to the shop so my alignment can be normal, and i get back to pick the car up and my tires are rubbing against the wheel well. (REAR ONLY)that little lip that wraps from the outside of the car to the inside. and has the spot welds to hold the panel on. so i was talking to one of my friends and he said i could get the wheel well rolled out so i can fit my 16" rota's with Falken Azenis. so i lifted the car and put my stock rims on(EX) and it doesnt rub. dam car is too low but i refuse to get new springs. anywayz does anyone have a thought on how to hadnle this problem? thank you.sorry so long
Old Oct 27, 2004
robbclark1's Avatar
Retired suspension supermod.
that is because you had the alignment set to stock! You can't have it set to stock or you will rub You need more negative camber or roll the fender.
Old Oct 27, 2004
exturbo6's Avatar
k. how much do you think it would cost to get my fenders rolled?
Old Oct 27, 2004
robbclark1's Avatar
i dunno. You can do it yourself, but you might bend your fender or crack your paint. Call up some body shops and ask them if they will do it. If they won't call up your local speed shop and ask them who they might recommend.
Old Oct 27, 2004
exturbo6's Avatar
good looks
Old Oct 29, 2004
VNlilMAN's Avatar
The Standard One
i have 18s and mine dont even rub...
it barely clears it. The alignment shop should have set the alignment so that it doesnt hit. Usually it'll still be within spec.
But yeah I also rolled my fenders a little bit using a baseball bat.
To do that just jack the car up enough so that you can fit a bat in between the fender and tire. than just push the bat down(toward the center of the rim) and that should bend the fender lip a little. just keep going around the top of the fender
Old Oct 29, 2004
flotsamm's Avatar
Or take to a body shop and have it plasma cut.
Old Oct 31, 2004
dtexan's Avatar
dtexan is an unknown quantity at this point
If you do roll them yourself use a heatgun to heat up the paint. It helps in preventing cracks in the paint
Old Oct 31, 2004
exturbo6's Avatar
i found a shop that will do it for 30 bucks. i know someone who had 19's on a honda and he get his fenders roll in and it work great and looked good.
oneheadlight
Apr 29, 2015 11:30 PM
bsmiley
Apr 27, 2015 01:27 PM
bo_red
Apr 23, 2015 10:09 PM
GH04si
Apr 15, 2015 08:13 PM
ImmortalEX
Oct 31, 2001 10:00 PM
