Front Sway Bars are available
Old Oct 12, 2004
ctv's Avatar
ctv
ctv is an unknown quantity at this point
I know there is a Progress Front sway bar we can get but who else makes
them fro the front?
Old Oct 12, 2004
PunkingCivic's Avatar
I need TP for my bunghole
H and R, 26mm
http://www.tornactive.com/pd_hr_sway_bar_rsx_02up.cfm
Suspension Techniques, 1"
http://dezod.com/pd_suspension.cfm
Neuspeed, 27mm
http://www.nopionline.com/index.cfm?...20Bar&vaffid=0
Old Oct 12, 2004
runner1738's Avatar
since when has neuspeed had one for the front? i thought it was only for the rsx and si?
Old Oct 12, 2004
runner1738's Avatar
http://www.neuspeed.com/products/pro...type=ns_import
if you go to there site ill youll see are the bushings for the front bar, not the bar, so does it fit or what?
Old Oct 12, 2004
gotarheels03's Avatar
gotarheels03 is an unknown quantity at this point
I think eibach also makes front and rear bars. I thought I saw them on Tirerack recently
Old Oct 12, 2004
ctv's Avatar
ctv
i was looking for something a little smaller than 27mm
I think ill just do the bushings, i can get them for $3.50 ea front and rear
Old Oct 12, 2004
pnoyster2k1cvic's Avatar
Balut Eating Champ
i know this is totally different answer... but just my suggestion, why don't you get an X-Brace instead... it's way cheaper, performs better (o2x proven by me ) and not get in the way of your exhaust, and can be installed in less than 15mins ... unless otherwise you broke yours... just my .05
Old Oct 12, 2004
ctv's Avatar
ctv
thanks for the advice, maybe i'll add that after i do the bushings
chris
Old Oct 12, 2004
runner1738's Avatar
why not x brace and progress sway bar with bushings lol? is it ever to much? when do you know its enough?
Old Oct 12, 2004
Zzyzx's Avatar
Autocross Junky
...a Front anti-roll bar and an X-Brace or other lower subframe brace do 2 completly different jobs....
ctv, if you want to upgrad your front anti-roll bar and don't want it too big, May I suggest either an 01-02 Coupe 25.4mm or an 02 Sedan 22mm bar....
Personally I've actually down sized my Front bar from the 25.4mm to the 03+ 15.9mm bar.
Old Oct 12, 2004
runner1738's Avatar
do the neuspeed anti roll bars snap endlinks as easily as progress?
Old Oct 12, 2004
ctv's Avatar
ctv
odd, why did Honda go smaller???
where the early ones Hollow?
Old Oct 12, 2004
chicohonda02's Avatar
Since 2002 Baby!
This is all go, but for some reason I'm confused with all the diff sizes and why size matters. Well you know what i mean..
Old Oct 12, 2004
cubanmike26's Avatar
^^^You had a similar question as Nindoo:
Originally Posted by nindoo
Why did Honda drastically change the set up on the 03 in comparison with the 02?
Answer:
Originally Posted by robbclark1
It is to induce understeer which is safer for stupid drivers.
Old Oct 13, 2004
ctv's Avatar
ctv
thnaks, now to get me a 22mm bar from a 02 sedan
Makeice3498
Jul 2, 2015 11:13 AM
mrohitredd
Jun 9, 2015 06:37 AM
Rogelio Rey
May 24, 2015 08:30 PM
Dorval Andre
May 1, 2015 09:37 AM
bsmiley
Apr 27, 2015 01:27 PM
