Suspension problems - Konis w/ Eibach Prokit
Old Oct 5, 2004
mmm2donuts's Avatar
mmm2donuts is an unknown quantity at this point
Ok guys here's my problem. I bought a set of Konis from a friend who traded in his 2002 EX for an 04 Si. I replaced the Neuspeed Race springs that were on them with an Eibach Pro-kit because the Neuspeed Race springs were too low. The rear suspension is really bouncy.....i mean REALLY bouncy. Its bouncy on even a smooth surface. Im running 215/45/17 Kumho's. Also whenever i hit even the smallest imperfections in the road, i hear a thud sound coming from my right rear fender area. Im not too sure what's wrong with them because im pretty much an idiot when it comes to suspension. The springs were professionally installed at the Honda dealership i used to work at, so im pretty confident that its not an install issue. Any idea what's wrong????
Old Oct 6, 2004
mmm2donuts's Avatar
anyone???
Old Oct 6, 2004
dragoon's Avatar
check the settings (****) on the konis, probably set to very hard
Old Oct 7, 2004
someguy's Avatar
someguy is an unknown quantity at this point
that would be my guess. or the shocks might be gone....might have to take them in to get re-valved.
Old Oct 7, 2004
Ruking's Avatar
Ruking is an unknown quantity at this point
Given no installation issues or blown dampers, check the rears (or have them checked) and set your rear shocks to pretty close to, if not, "full soft". For Konis especially, it does not take much, nor can you be completely sure where in the adjustment scheme you are with the full 2 turns of adjustment (adjusted with an allen wrench, whose size escapes me as I write this, i.e., no click stops. So for experimental purposes you can use a black sharpie to mark. You may also want, as a baseline to set your fronts to "med to slightly soft". As you define your preferences, you can adjust from there. The good news is that set on full soft; it is between 15-20% stiffer than stock.
Old Oct 7, 2004
jdm_bb's Avatar
jdm_bb is an unknown quantity at this point
yea it might be set to the hardest
Old Oct 7, 2004
PCaly2112's Avatar
PCaly2112 is an unknown quantity at this point
Yeah, i've had my konis set on hardest setting with my 18's and its a rough ride, specially on some of the horrible PA roads ::cough:: 422 ::cough::
Old Oct 7, 2004
PCaly2112's Avatar
o yeah, i have the eibach pro-kit installed as well, meant to mention that in my post
Old Oct 7, 2004
mmm2donuts's Avatar
ok guys thanks for your help....ill get it checked out this weekend.
Mad Dog Tannen
Oct 19, 2016 08:12 PM
cukaracha
Aug 29, 2015 05:27 PM
protoCall7
Bolt-on Engine Performance
Jul 26, 2015 07:41 PM
VNlilMAN
Oct 19, 2006 08:09 PM
Intermezzo
South Cali
15
Oct 2, 2002 08:54 PM
