Comptech Rear Sway Bar
Old Oct 4, 2004
Shlomo's Avatar
Shlomo is an unknown quantity at this point
Does anybody have this rear sway bar? I was thinking of getting it because it's only 98 bucks from dezod. Any opinions on it? Thanks.
Old Oct 4, 2004
Boilermaker1's Avatar
Jap-Euro Fusion
I have one. Its an 11 lb stick of metal that does what its supposed to. What more is there to say?
Just make sure you got a tie bar and some heafty springs.
Old Oct 4, 2004
Shlomo's Avatar
i was just wondering why it is so much less expensive than the progress bar...is it because the progress bar comes w/ a lower tie bar (the metal piece w/ "progress" on it)?
Old Oct 5, 2004
robbclark1's Avatar
Retired suspension supermod.
yes, it is because progress comes with a tie bar.
Old Oct 5, 2004
Jap-Euro Fusion
Yes, its just the bar. If you want the comptech one with the cradle, its $400.
The difference is that the Comptech bar fits right, the progress one doesn't really. The arms on the progress bar are too long and if you look at the endlinks when the bar is installed, they're pushed way off of vertical.... which is why all the endlinks are breaking.
Old Oct 5, 2004
CrazyCakes's Avatar
CrazyCakes is an unknown quantity at this point
is the comptech bar w/o the cradle still adjustible???
Old Oct 5, 2004
Shlomo's Avatar
so, w/ the comptech bar we do not need new endlinks?
Old Oct 5, 2004
PunkingCivic's Avatar
I need TP for my bunghole
Here is the comptech swaybar and tie bar combo
Old Oct 5, 2004
TeLLy's Avatar
Yes, it's an Acura EL
If you're going to a sway bar bigger than 19mm, it's advisable to get new aftermarket endlinks anyway IMO. The stockers are pencil-thin, literally, and the ball joint on them is, in my opinion, unreliable - I was able to pop one out with one hand and a pair of pliers. Just imagine a 22mm BAR subjected to a whole car's cornering force, yanking at it.
Old Oct 5, 2004
Jap-Euro Fusion
There are 2 comptech bars. The $99 bar is the same one that comes with the Swaybar/Cradle combo for $400. The Comptech Race swaybar is $650 and thats adjustable.
Old Oct 5, 2004
Jap-Euro Fusion
If your rear springs are stiff enough... no, you shouldn't need new endlinks. If they're not and the car is still going to roll to the point where the sway bar is going to flex in the endlinks a lot, then yeah, you'll probably still break them.
Old Oct 5, 2004
Shlomo's Avatar
i was looking on the comptech website and was trying to find some part #'s, is 140-115CLR the right part #?
also, would it be feasible to buy the sway bar and then the tie bar separately and then buy the correct bushings? $400 seems pretty steep in relation to the $99 for just the sway bar.
pizzahutcombo
Suspension
Jul 13, 2021 09:41 PM
juror
Suspension DIY
Jul 30, 2019 03:28 AM
Marco83
Oct 13, 2018 10:13 PM
GotSiR
Jun 23, 2016 04:06 PM
muniorbust
33
Aug 31, 2015 08:59 PM
