Sway bar bushing question
Old Oct 4, 2004
gh0st's Avatar
TAQUITOS!!!!
I installed my rsx rear sway bar with the ES bushings & brackets.
I have an EX and the oem bushing brackets don't seem to fit over the ES bushings, so thats why i used the brackets that came with the ES...
will the RSX brackets hold the ES bushings? Are the ES brackets fine?
if this has been asked, i didn't see it ...and i know people say that the stock brackets will work fine with the bushings, but i'm not sure if they're talking about the rubber rsx bushings or the ES bushings...
if someone can help me or point me in the right direction...thx
(if need be, )
Old Oct 4, 2004
Diver's Avatar
Diver is on a distinguished road
I would like to know also since I might be doin same install real soon
Old Oct 4, 2004
TeLLy's Avatar
Yes, it's an Acura EL
Use RSX bushings with the stock Civic brackets. Either that, or if you're using ES bushings you should use the ES brackets as well, as the ES bushings are curved differently from the OEM RSX/Civic ones and as such won't fit the stock brackets.
For like 5 minutes I thought you meant "ES" as in the sedan chassis code, LOL. Took me a bit to figure out you meant "Energy Suspension". I"m a lil slow today.
Old Oct 5, 2004
Boilermaker1's Avatar
Jap-Euro Fusion
Use the ES brackets... thats why they gave them to you.
juror
Suspension DIY
Jul 30, 2019 03:28 AM
GotSiR
Jun 23, 2016 04:06 PM
breanna_17
Jul 21, 2015 04:01 PM
muttleytm
Jul 14, 2015 05:31 PM
fordover
Jul 11, 2015 09:10 PM
