DIY alignment?
Old Sep 29, 2004
Big Baller L's Avatar
Nugget Garage Since 2004
Question DIY alignment?
Whats u everyone.
Ive recently been horsing around with different camber settings on my back wheels, and changing ride height and such, so im just wondering if it is possible to buy all the tools needed to do an alignment myself? I dont want to pay again to get it done, since all the stock stuff is going back on for winter time anyways, so is it possible. I think grey said he can do it himself so grey if u read this let me know what you do.
Thanks
Landin
Old Sep 29, 2004
Zzyzx's Avatar
Autocross Junky
... you realize that by changing camber and ride height you are also changing the toe settings... and bad toe settings are 10X worse then bad camber settigns (In regards to tire wear)
and to answer your question, Yes it is possible to buy the equipment needed to do your own alignment
Turn Plates
http://www.racerpartswholesale.com/long20.htm
For Camber and Caster
http://www.racerpartswholesale.com/long17.htm
or
http://www.racerpartswholesale.com/art1.htm (only measures camber)
For Toe
http://www.racerpartswholesale.com/long19.htm
http://www.racerpartswholesale.com/art2.htm
or....
the $50 DIY alignment Rack...
http://www.honda-tech.com/zerothread?id=267237
Old Sep 29, 2004
^yah i know thats why i want to fix it right away. Would the diy thing work for all alignment setting, cuz it seems like all the other options are much more expensive.
Old Sep 29, 2004
tfnaaf's Avatar
BLDNPSI Mod
not ture, worn out tires because of improperly set alignment would be much more expensive than an alignment
Old Sep 30, 2004
no i meant one of the options he posted...http://www.honda-tech.com/zerothread?id=267237
that one seems really cheap compared to the other ones, so im just wondering if i can do everything with that one set-up.
Old Sep 30, 2004
Zzyzx's Avatar
Autocross Junky
^^ thats a do it your self Toe alignment rack.... The accuracy depends greatly on you.
Old Sep 30, 2004
^okay i see....as for camber i can pretty much do that by eye, i mean its pretty obvious when u have camber. I mean i did it myself when i did the suspension just to get it close, and when i got to the alignment shop it was already within spec.
So if i use the toa alignment rack then im all good except for the front caster, and i can get the other thing to do that correct?http://www.racerpartswholesale.com/long17.htm
Old Sep 30, 2004
Zzyzx's Avatar
Autocross Junky
Caster isnt adjustible on our cars, unless you have added parts athat allow it (Camber/caster plates..)
Old Sep 30, 2004
tfnaaf's Avatar
BLDNPSI Mod
and from my exp. of doing alignments for 19 years give or take, the best that you'll be able to get camber eyeballing it is + or - .5 if your lucky
Old Sep 30, 2004
zzyzx: so i dont need to worry about caster then? its just toe and camber. And realistically i can get my camber close enough, cuz ive done it before (rear left was -1.0 and rear right was -1.5) this was before the alignment. It was noticable that i still had negative camber, but i left it for them to do.
So what tool do you think would be the most economical, and the easiest to use, because there are lots of different options
Old Oct 3, 2004
Stratablak314's Avatar
Stratablak314 is an unknown quantity at this point
After I got my wheels/tires/springs I took my car to Sears to get the alignment checked. They said they don't need to check it because it is not adjustable on our cars. I thought this was total bs. Called another shop and they said they'd have to hammer on the knuckles to fix alignment on my car which would have cost me $400 in labor when i could buy a 100- 200 front and rear camber kit and put it on my self.
GolNat
Nov 27, 2018 03:32 PM
Tedverseti
Sep 29, 2015 05:41 PM
Wariogamer
Sep 29, 2015 09:49 AM
speedlever
Sep 24, 2015 07:18 PM
TheRiddicles
Sep 21, 2015 01:28 AM
