19mm rsx sway bar...
Old Sep 29, 2004
prccivic's Avatar
I bought a 19mm sway bar off an rsx owner.....what mounting kit do i need to buy to install it?
Old Sep 29, 2004
TeLLy's Avatar
Yes, it's an Acura EL
Says in your profile you've got an EX sedan. Thus you already have a sway bar, which means you can re-use your stock sway bar brackets, but you'll need new bushings. If they didn't come with your bar, you can buy a pair from your local Acura dealership for about $20 for the pair (or less). You can reuse your stock endlinks, but those bastard things have a tendency to strip thus making it hard to remove...you may have to resort to ripping the suckers off and replacing with new ones from Honda...but I recommend Grey's endlinks (contact him via PM or search the forum for details). Install is pretty easy.
Old Sep 29, 2004
prccivic's Avatar
Originally Posted by TeLLy
Says in your profile you've got an EX sedan. Thus you already have a sway bar, which means you can re-use your stock sway bar brackets, but you'll need new bushings. If they didn't come with your car, you can buy a pair from your local Acura dealership for about $20 for the pair (or less). You can reuse your stock endlinks, but those bastard things have a tendency to strip thus making it hard to remove...you may have to resort to ripping the suckers off and replacing with new ones from Honda...but I recommend Grey's endlinks (contact him via PM or search the forum for details). Install is pretty easy.
alright...thanks man
Old Sep 29, 2004
TeLLy's Avatar
I live to give. And also take, with extreme force. Enjoy the sway bar, you'll be cornering like a go-kart, it's great!
Old Sep 29, 2004
prccivic's Avatar
ya i know...i can not wait...i gotta buy a new rear drivers side shock...then the sway bar will be installed...can't wait
Old Sep 30, 2004
RedDragon333's Avatar
I didnt have to use gresy endlinks. Once i figured out how to remove the sway bar from the stock endlinks it was an easy install. Just remember to have the proper allen wrench and some WD40
Old Sep 30, 2004
prccivic's Avatar
so u just used the stock endlinks?
Old Sep 30, 2004
Yakkolio's Avatar
Yakkolio is an unknown quantity at this point
yup use the stockies
Old Sep 30, 2004
gh0st's Avatar
TAQUITOS!!!!
i got the ES bushings and the stock brackets for the oem sway bar don't seem to want to fit over the ES. Did I not try hard enough or should i pick up some rsx brackets? right now i'm using the brackets that came with the ES bushings
Old Sep 30, 2004
Pn0ybOiLiKehOy's Avatar
Pn0ybOiLiKehOy is on a distinguished road
i ripped my endlinks after putting the 19mm on my car..just pay attention to how it is on before u take it off. i think part of my problem was that i just took it off and was too excited, i didnt check how it went on before welll...have fun
rovafa2002
Sep 28, 2015 06:57 PM
beanhead
Sep 24, 2015 12:04 PM
PunX
Sep 23, 2015 10:45 PM
TheRiddicles
Sep 21, 2015 01:28 AM
Viczhou
Sep 2, 2015 07:55 PM
