SPC vs Function 7 Lower Control Arm
Old Sep 27, 2004
AceKicker's Avatar
AceKicker is an unknown quantity at this point
Hey guys what is the big difference between the SPC vs Function 7 lower control arms? if you have pics post them please. and what are the cost between the two. Also where can you buy them at? I know I would like to know the info and maybe other people also. Thanx again for all the help guys.
Old Sep 27, 2004
Mr.Modify's Avatar
you can get them from danscreation a member on here.
Old Sep 28, 2004
Grey's Avatar
DIY King
The Function7 rear lower control arms are only 1.2lbs each, while the SPC lower control arms are 1.44lbs each.
Check out this thread for more info. and pics of the SPC ones: SPC Rear Lower Control Arms
Check out this Ebay page for more info. and pics of the Function7 ones: Function7 Rear Lower Control Arms
I have the Funciton7 rear lower control arms. They look sweet! I'll be installing them and writing a DIY soon. Stay tuned...
Old Sep 28, 2004
ctv's Avatar
ctv
ctv is an unknown quantity at this point
nice tell us how the F7 are i may get a set
a little expensive over the SPC though
but looks like its worth it
Old Oct 4, 2004
Function7's Avatar
Function7 is an unknown quantity at this point
We noticed you guys were discussing our arms, and figured we'd give you the details on our product so you can make an informed decision.
1. All the materials we use are batch certified and each arm (we use 7075 aluminum, 15%-18% stronger than 6061) is individually serialized/bar coded. This gives us the ability to track each arm, the material batch, manufacturing date, which lets us support our product better and also offer a lifetime warranty on the arms.
2. Our arms come with entrapment-type polyurethane bushings (from Energy Suspension) with our own CNC'ed aluminum bushing inserts. This means that no stress-causing set screws are used to hold the bushing in place.
3. The arms are designed with full-width bushing journals to make the arm as strong as possible. Although we start out with a larger block of aluminum that way, we "cut out" even aluminum to give lighter, stronger arms.
4. We designed the arms with aluminum bushing inserts to get around the rust factor. This means that your suspension bolt will not sieze up in the bushings and makes the long term maintainence easier.
5. Our designs are 100% CAD designed then passed through proper structural analysis. The prototypes were then installed on a few race and street cars for an extended test.
6. We manufacture all our arms in-house (right here in Mesa, AZ) on our high-precision aerospace CNC mill. Our materials, etc all come from US suppliers to ensure the highest quality.
Because we make our arms right here in the USA, and with better materials, and we start out with larger blocks of aluminum, our arms cost a little more than our competitiors. The current street price is $199.99 + shipping.
Please feel free to email/message us if you have any other questions about our products.
Thanks!
-A
Old Oct 4, 2004
robbclark1's Avatar
Retired suspension supermod.
both look good, but function7 doesn't come with a socket to take off the 3 10 star bolts that Honda put on. SPC does. You guys might want to include that.
Old Oct 5, 2004
AceKicker's Avatar
So what about the weight difference what is the weight difference between the SPC and the Function 7 control arms.
Old Oct 6, 2004
Grey's Avatar
DIY King
Check out my 3rd post in this thread.
Old Oct 6, 2004
robbclark1's Avatar
Curt
reading > you
Function 7 dude - are those endlinks universal and how much are they?
Old Oct 6, 2004
jturbolx's Avatar
jturbolx is a jewel in the roughjturbolx is a jewel in the roughjturbolx is a jewel in the rough
the 10 star bol is only 12 point socket btw =)
Old Oct 6, 2004
robbclark1's Avatar
no it isn't. sockets come in 6 or 12 star. The honda bolt is 10 star. Trust me, you need a special socket.
Old Oct 6, 2004
jturbolx's Avatar
interresting
Old Oct 6, 2004
jturbolx's Avatar
"Because we make our arms right here in the USA, and with better materials, and we start out with larger blocks of aluminum, our arms cost a little more than our competitiors. The current street price is $199.99 + shipping.
Thanks!"
hey wondering if you are interrested in wholesale inq??
let me know jason@whitelineperformance.com
Old Oct 7, 2004
AceKicker's Avatar
Originally Posted by robbclark1
Curt
reading > you
now now rob be nice. no i had to ask something and that was the first thiing that came to me. But I ended up reading it later on
Old Oct 16, 2004
Function7's Avatar
Yes they are universal but really meant for our EG/EK/DC2R customers since we offset the mounting holes to accomodate the weight difference of the arms. The endlinks are $39.99 a pair. However for customers who have purchased our arms, they are $34.99.
Thanks
-A
Old Oct 16, 2004
Function7's Avatar
Yeah we do. Please PM or email me at info@function-7.com
Thanks
-A
Old Oct 16, 2004
Function7's Avatar
doh... didnt mean to post twice.
-a
Old Oct 16, 2004
robbclark1's Avatar
So can you give me anymore info on the endlinks? Materials? Can they be used on a EM2 (7th gen civic)?
Old Oct 16, 2004
Zzyzx's Avatar
Autocross Junky
Any plans on making a front lower control arm??? Perferably one that will allow us to adjust camber and Caster, for Us autocrossers and road racers? :Wink: :Wink: :Nudge: :Nudge:
Old Oct 17, 2004
obguam's Avatar
obguam is an unknown quantity at this point
Bump for answer to Zzyzx's good Q.
Old Oct 17, 2004
AceKicker's Avatar
I want to know if you plan on doing a GB on the control arms.
Old Oct 17, 2004
Function7's Avatar
Our universal endlinks are ductile steel (so they dont snap under shock loads) and come with a 10mm x 1.5mm threaded shaft/threaded hole and gives about 1-1.2" of length adjustment to help you neutralize the pre-load in the sway bar. We have mounting hardware that lets it fit 8mm and 10mm mounting holes. All mounting hardware are grade 12 socket (allan/hex) bolts that meet or exceed current Honda specifications.
The ball joints have brass bushings and a stainless steel ball for longevity. Each joint is greasable via a mini grease nipple.
They should be able to fit an EM2, we've had them installed on our prototype DC5
Thanks
-A
Old Oct 17, 2004
AceKicker's Avatar
well what about my question and zzyx question.
Old Oct 20, 2004
Function7's Avatar
Unfortunately our retail agreements with our retailers and distributors no not allow us to do group buys.
-A
Old Oct 20, 2004
AceKicker's Avatar
damn taht sucks. well do you guys plan on make a front control arm for our cars?
Old Oct 20, 2004
wonderz's Avatar
wonderz is on a distinguished road
where can you buy this special socket?
Old Oct 20, 2004
robbclark1's Avatar
You can't, you have to get it from someone who has bought the SPC arms. Grey needed one. Ask him where he got his.
Old Oct 20, 2004
taz757's Avatar
Or know a Honda mechanic that might be able to get the socket for you.
Old Oct 20, 2004
nindoo's Avatar
Why is my vagina bleeding?
How much do the stock control arms weigh?
Old Oct 20, 2004
civicvtec1ps's Avatar
Search and Learn
Like close to 4lbs each.
You aren't saving much weight.
