SPC vs Function 7 Lower Control Arm
Old Oct 21, 2004
  #31
Grey's Avatar
DIY King
Originally Posted by robbclark1
You can't, you have to get it from someone who has bought the SPC arms. Grey needed one. Ask him where he got his.
I wish I had one already. I don't though. I haven't found anyone yet. I might try my Honda dealer though...
Old Oct 21, 2004
  #32
rijowysock's Avatar
ThE FaMiLy SeDaN
whats the benifits besides strenght and looks? its not that much lighter.. do they REALLY make a diff? j/w
Old Oct 21, 2004
  #33
robbclark1's Avatar
Retired suspension supermod.
no, for us, they don't make a difference.
Old Oct 21, 2004
  #34
gtracing's Avatar
TeLLy is my daddy
gtracing is an unknown quantity at this point
yea, i'm guessing just cosmetics...but i'm really interested in a set since ours look so ghetto...
Old Oct 21, 2004
  #35
gtracing's Avatar
TeLLy is my daddy
btw, f7, u guys have a website?
Old Oct 21, 2004
  #36
Zzyzx's Avatar
Autocross Junky
If you are chasing down that last hundredth of a second they may be worth it.....
Old Oct 22, 2004
  #37
rijowysock's Avatar
ThE FaMiLy SeDaN
lol.. well for me.. theyd look cool when jacked up.. i cant even see any of my undercarraige... well anything for that matter.. shes sitting on the ground....
Old Oct 22, 2004
  #38
AceKicker's Avatar
AceKicker is an unknown quantity at this point
Hey GT here is their web address it is still under construction but they do have a link on where to buy the control arms. www.function-7.com
Also the benefits they have is that they are lighter, they look alot better, they are stronger, they flow air thru the arms which will cause less air distortion(alot of people didnt know that) and they have the Function-7 ones have Energy Suspension Polyurethane Bushings which means they are better for handling So over all they are 100 times better. I hope this helps everyone.
Old Oct 22, 2004
  #39
wonderz's Avatar
wonderz is on a distinguished road
are the F7 one really stronger than the SPC ones?
Old Oct 22, 2004
  #40
AceKicker's Avatar
well from what F7 says the Function-7 control arms are made out of 7076 grade aluminum or something like that and the SPC are made of 6061 grade aluminum or soemthing like that. I jsut know that the Function-7 metal grade is higher which means stronger.
Old Oct 22, 2004
  #41
Grey's Avatar
DIY King
I took physics for 2 years at a good college before I changed my major to computer science and I can tell you that they are better. Much better actually. 15% - 20% stronger overall because of the material. The design is also better than the simple holes in the SPC lower control arms.
As AceKicker mentions, the polyurethane bushings make them better than stock. Less flex when throwing your car sideways, so you get less tire movement. Also, the holes do allow for airflow, BUT... Is it the kind of airflow that makes the car more aerodynamic? I don't know about that, it takes a lot of calculations to determine whether that is true.
One other thing that people don't mention is that the weight difference helps out in ways you don't think of. In one way it's not good to get rid of weight in the rear since it makes the car even more nose heavy. In another way, it's good to get rid of the weight in the suspension because it is quicker to react. So... Certain bumps will cause the stock suspension in the rear to not compress at all because of the inertia of the suspension, but the smaller inertia (because of the weight difference) with the Fucntion7 control arms will allow the suspension to compress and relax more and therefore keep the tire in contact with the road more.
Old Oct 22, 2004
  #42
robbclark1's Avatar
Grey as much as I would like to believe that, and I do to a certain extent, if you look at our control arm it isn't like older civics. They had their assembly attached only to the control arm. We have a trailing arm that is physically attached and doesn't move (besides the movement the bushing allows). I really don't think by changing the control arm piece will make that big of a difference. Bushings, maybe, but not the arm. A few pounds, if you are really really scraping for the last little bit of time, won't do much for the suspension set up.
Old Oct 22, 2004
  #43
Zzyzx's Avatar
Autocross Junky
a reduction in unsprung weight, however small, still helps.
Old Oct 22, 2004
  #44
Grey's Avatar
DIY King
I don't know how much it helps practically, but theoretically it does help. That's all I'm saying.
Old Oct 22, 2004
  #45
AceKicker's Avatar
All we know is that they are stronger lighter and look alot better so if that isint beneficial enough then i dont know what is. lol
Old Nov 4, 2004
  #46
Function7's Avatar
Function7 is an unknown quantity at this point
(Back from vacation...)
Grey covered most of it, thanks Grey. The material we use (7075-T6) is about 15-20% stronger than 6061-T6, and they are certified batches so that we are able to track the quality of the materials, the manufacturing batch etc, after the arms are sold so as to be able to warranty our products.
You are right in that the rear control arm, in it's current design, experiences significantly less force. This is mainly due to the struts are now connected to the trailing arm instead of the suspension arms like the earlier EF/EG/EK models. However there is a significant amount of lateral force being transmitted along the length of the arm when the car is subject to turning loads.
The design of the stock arm (stamped steel plate) allows it to bow out slightly when lateral force is applied, so some amount of stiffness is compromised. Study it closely, you'll find that the stock arms taper from 6mm to about 4mm in the center and then back to 6mm at the bushing end. Our goal in designing the 7thGen Civic/RSX arms is to develop a stiffer and more rigid 3-dimensional structure (as opposed to a flat steel plate) while reducing unsprung weight, and improving airflow. Despite its open structure, our arms are also designed for a 150-ton shock load - and they have lived up to the design specs in our extended testing.
Thanks
-A
alxz310
Jul 30, 2015 12:18 PM
Jul 12, 2015 11:54 AM
aultman1990
Jul 9, 2015 08:27 PM
ballmich
Jul 9, 2015 11:59 AM
CivicsClass101
Jul 9, 2015 11:14 AM
