Need help fast installing Tie bar
Old Sep 21, 2004
VTECTypeR's Avatar
Im installing my tie bar and I was wondering when i take out that screw where the tie bar is supposed to go is anything gonna fall off or come out of its place. And should the wheels be on the ground or off the ground?
Old Sep 21, 2004
robbclark1's Avatar
Retired suspension supermod.
Nothing will fall out per se, but brace the control arm with a piece of wood so you can align the hole up easier.
Old Sep 21, 2004
VTECTypeR's Avatar
O ok that what i was worried about the control arm getting out of place.
Old Sep 21, 2004
VTECTypeR's Avatar
Ok somehow the control arm got unaligned and i cant put the screw back Plz help immediatly. I cant align it for some reason.
Old Sep 21, 2004
VTECTypeR's Avatar
I got the screw in now. But im almost done screwing. But it just wont go in all the way. What the heck is wrong. I cant drive with it being half in plz help me
Old Sep 22, 2004
robbclark1's Avatar
It should go in all the way. Just keep screwing or push the control arm up with a jack.
Old Sep 22, 2004
VTECTypeR's Avatar
Ok you know how theres the first part where you screw it in then you have to shove the screw in to the second part where it has to be screwed. Thats where im stuck at right now. I did put a jack under and everything was aligned I dont get whats wrong.
Old Sep 22, 2004
TeLLy's Avatar
Yes, it's an Acura EL
Rubber mallet it through perhaps?
Old Sep 22, 2004
VTECTypeR's Avatar
No I cant just do that. It has to be screwed in
Old Sep 22, 2004
TeLLy's Avatar
Well, you have to get the thread out to the other side right? In this case I'd keep turning it to see if the threads catch or just rubber mallet till the bolt comes through on the other side, then start turning it.
Old Sep 23, 2004
VTECTypeR's Avatar
I tried that and it got there but now I have a feeling I may have stripped the bolts. I went to my honda dealer they didnt have it in stock. They wanted almost 4 bucks for some bolt lol. Either way I was going to get it.
Old Sep 23, 2004
TeLLy's Avatar
So are you at least bolted up now?
Old Sep 23, 2004
pnoyster2k1cvic's Avatar
Balut Eating Champ
give it a little shake and pound it at the same time... won't go in? pull it out first and see what's restricting the bolt to go in before you break/strip somthing... maybe a WD40 would help...
ibilalx
Jun 17, 2015 11:00 PM
BootyDo
May 7, 2015 04:46 PM
Dorval Andre
May 1, 2015 09:37 AM
0100010
Bolt-on Engine Performance
Nov 26, 2001 07:50 PM
BiGbRoWn
Nov 21, 2001 06:17 PM
