Good non-performance strut replacements?
Old Sep 18, 2004
BigNate's Avatar
BigNate is an unknown quantity at this point
I can't find any reviews of the KYB GR-2 struts, and all the old discussions I've found focus on performance and/or lowering. My suspension is totally blown. I have to take speed bumps at around 1 mph to avoid seriously loud rear suspension noise and bottoming out. I was just wondering if the GR2s will restore a good ride quality and be semi-durable?
Old Sep 18, 2004
Zzyzx's Avatar
Autocross Junky
Tokico HP would be a good chioce. they are the Blue ones, non adjustible.
Old Sep 18, 2004
BigNate's Avatar
Any comparisons between the KYBs and Tokico HP for durability and ride quality?
Old Sep 18, 2004
robbclark1's Avatar
Retired suspension supermod.
probably not.
Old Sep 18, 2004
CuRiOuSfIsH's Avatar
Back From The Banned!
1 member on here has the KYB's I think....
Old Sep 19, 2004
cubanmike26's Avatar
I read somewhere that you have to modify the Tokikos knuckle bolt size 2mm larger in order to install them on your car. Is this tru? I thought it was a perfect bolt on. Anyone knows??
Old Sep 19, 2004
robbclark1's Avatar
If you have a 03+, they need to be modified. I beleive the Tokico might be making ones for the 03+. give them a call. The 01-02 have 14mm mount bolts while the 03+ have 16mm.
Old Sep 22, 2004
82801BA's Avatar
82801BA is an unknown quantity at this point
I have stock RSX Type-S suspension bolted on Civic knuckles...New, a little bumpy, then began to be soft after about 10k....It's pretty comfortable now(I can say a lot better than stock Civic's ride quality)
Old Sep 22, 2004
Would the problem be solved by simply increasing the hole to 16 mm or do I need to modify them even more? I'm asking cause I plan to get them by the end of the month.
Old Sep 22, 2004
thoughthard's Avatar
thoughthard is an unknown quantity at this point
I have KYB GR-2 on my non-7thgencivic. I think they are a good OEM replacement. Maybe slightly firmer. They are not high performance by any means.
ayoitzjulesdx98
Oct 1, 2015 06:34 PM
superstanko
Apr 28, 2015 04:38 AM
bsmiley
Apr 27, 2015 01:27 PM
GH04si
Apr 15, 2015 08:13 PM
thesushiboy
Apr 12, 2015 02:54 AM
