How many people have noises???
Old Sep 17, 2004
civicrice's Avatar
civicrice should not be trustedcivicrice should not be trusted
i know this has been covered before, but. i cant figure out how to fix it. when i turn my wheel i hear clunking. how many people have this problem and what is the correct solution to fix it? really annoying.
Old Sep 17, 2004
tripledoublegs's Avatar
Euro-Spec
what's your setup?
Old Sep 17, 2004
civicrice's Avatar
neuspeed sports. everything else stock
Old Sep 17, 2004
matrix311's Avatar
matrix311 is on a distinguished road
I have clunking noises too when it turn my wheel and the car is not moving. I have a D2 coilover kit.
Old Sep 17, 2004
MrWong's Avatar
Bushido
MrWong is an unknown quantity at this point
I have no noises I the have Tein SS
Old Sep 17, 2004
gh0st's Avatar
TAQUITOS!!!!
i have noise on the v1 hayames...3rd nut keeps coming loose.
sounds like you might need the 01 upper mounts?
Old Sep 17, 2004
civicrice's Avatar
what is 01 uppper mounts?
Old Sep 17, 2004
Caucasian.Asian's Avatar
mine does it also, i have tein s. techs. i don't really notice it anymore though. i think its just because i don't pay attention to it anymore
Old Sep 17, 2004
poogiboy's Avatar
poogiboy is an unknown quantity at this point
mines do the same i have the neuspeed sports also and every since its been clucking and making noises ...
Old Sep 17, 2004
IrockCivics's Avatar
mines does the same **** and its not even drop I took it to the dealer yesterday to see what the hell could that be and the guy said that my front suspension might be loose and they aint fix it cause I had a strut bar there they said that thats aftermarket so he cant touch it, so now tomorrow I gotta go to the shop where they install my stock suspension and see whats up.
Old Sep 17, 2004
civicrice's Avatar
it sucks, yea please find out what it is and let us know. thanks
Old Sep 17, 2004
hustlelikem0fo's Avatar
ever since i lowered my front TeinSS all the way i hear a creakign sound when i turn my wheels at a stop
Old Sep 17, 2004
ZdS03Civic's Avatar
ZdS03Civic is an unknown quantity at this point
Try using WD-40 or Lithium grease. I have Ground Control coilovers and I used to have clanking...WD-40 made everything quiet.
Old Sep 18, 2004
civicrice's Avatar
what do you grease and where?
Old Sep 18, 2004
runner1738's Avatar
i dont have any coilovers or anything like that , but lately when driving on the freeway i hear a noise coming from the driver side wheel hub, not sure what it is wahtever , so i may just have to take it in and be like here fix it.
Old Sep 18, 2004
ZdS03Civic's Avatar
everything but the spring itself. Spray some oil on your shocks, lower perch, bushings, sleeves, etc.
Old Sep 18, 2004
flotsamm's Avatar
Alot has to do with how your struts were re-assembled if you put in aftermarket springs. You may not have your upper mount, upper spring perch lined up correctly with the hole on the lower spring perch. Here's a couple of pics of what I mean. See the two triangles on the top parts? Those triangles must line up with the hole circled in red below.
Thats one way to do it. The other way is by using the yellow paint marks. Which is the correct way? Hell I dunno.. I tried both ways and each worked fine. Also remember to seat the spring in properly both on top and bottom and preload the suspension a couple of inches with a floor jack before tightening up the top mount nuts and lower knuckle bolts. If you dont your steering wheel might not be centered. At least thats what helped re-center mine. Good luck.
Old Sep 18, 2004
civicrice's Avatar
i tried lining it up but i only seen an arrow on the top thing. i lined up holes? still makes the sound. im about to take it somewhere and let them figure it out
Old Sep 18, 2004
nice picture, i've seen the diagram, but the pictures let me understand it better. now i can try and correct it.
i think there should be a sticky thread on here covering the noises. this topic is gone over almost every weak. some one write up a good thread with the most information they found on here and make it a STICKY!
alxz310
Jul 30, 2015 12:18 PM
Dani1993
Jul 24, 2015 09:02 AM
mokkush
Jul 14, 2015 04:05 PM
f575gtc
Transmission
Jul 13, 2015 09:16 PM
06Si_Girl
Jul 12, 2015 12:08 PM
