***springs twisted??***
Old Sep 13, 2004
civicrice's Avatar
civicrice should not be trustedcivicrice should not be trusted
i just got the neuspeed sports installed about 3 weeks ago. after trying to fix all the knocking and clunking coming from the front passenger side . still does it but not as loud . i found that the back springs twisted a little bit, you can see they used to be in the positioned place but the moved. anyone else's car do that? and does that effect the height?
Old Sep 13, 2004
FALKEN's Avatar
Civicforums Junkie
on my sedan with the Neuspeed sport springs the front passenger clicks when i turn the wheel without rolling the wheels...its not that bad though, its very faint...
no height differences at all either
Old Sep 13, 2004
VNlilMAN's Avatar
The Standard One
twisted as in its not sitting on the lower perch right? Just jack the car up and try turning the spring to the right position. might not be able to but its worth a try. if you cant, its probably not that big of a deal depending on where its at
Old Sep 13, 2004
civicrice's Avatar
yea i tried that. didnt work. its not sitting in the hole where it should be. i guess that is the perch. im too lazy to take the back struts out. so i guess ill live with it.
Mc7602
Sep 17, 2015 02:01 PM
Ocelaris
Interior DIY
52
Sep 10, 2011 06:43 PM
pheaton
38
Oct 8, 2002 04:44 PM
