I want to turn flatter (less body roll)
I have a 04 VP (no sways) what would be best for eliminating body roll? I was thinking strut braces and roll bars (maybe progress) suggestions?
progress has very good sway bars, get front and rear, if you cant afford both of them, get the rear, a front upper strut bar, i recommend neuspeed just because its the only solid piece out there, and some really good coilovers and you will be set.... the only rolls you'll have are the ones under your chin... have fun!!
I'm not sure on the technical details of the VP, but if it has NO sway bars, a 22mm rear sway bar will produce way too much oversteer... if there is no front sway bar and you don't have the $ for the whole progress kit, start with a front sway bar from another model civic then try a rsx rear sway bar.
Autocross Junky
strut bars will do NOTHING to reduce body roll.
Heavier springs (Higer spring rates) as well as geting a front(not too big) and rear anti-roll bar will reduce most of that.
timpan
May 18, 2015 07:06 AM
