anyone out their with tokico blues on 03+
Old Sep 5, 2004
jttegx's Avatar
OMNES AD UNUM
i wanted to know if anyone out their has had ANY problems with the tokico blues on their 03+ models? im still debating weather i should still risk going with these for my 03 or avoid them. so any members out their with an 03+ with tokico blues, let me know your expierence with them.
-any problems
-performance quality
-pros and cons
just about anything i should be aware of..
thanks
Old Sep 11, 2004
jttegx's Avatar
OMNES AD UNUM
bump, i know few people out their have an 03 with the tokico blues. i still want to know if drilling the knuckle bolts from 14mm to 16mm(?) was well worth it
give me some reviews before i purchase a set!
Old Sep 11, 2004
reytito's Avatar
just use 14mm bolts from a hardware store. thats how alot of 03 ppl with koni's do it.
Old Sep 11, 2004
flotsamm's Avatar
I think either way would be fine. Enlarging the hole 2mm is basically 1mm on each opposite end. There seems to be enough material around the hole that 1mm overall probably is structually safe. However, dont take my word for it. Perhaps contact Tokico first before doing anything and ask their opinion.
Old Sep 29, 2004
shmik1's Avatar
so, any word on whats best/safe? etc..im wanting to get tokicos now too, but if need be i suppose i could always wait till feb, or whenever they release for the 03..
about using 14mm bolts, what kind specifically are needed to be safe and make sure they're strong enough?
anyone know first hand?
Old Sep 29, 2004
Ledbelly's Avatar
Im the man in the box
i got tokicos on my 04 and i say they'll well worth it the suprise me all the time
thier very responsive and stay smooth riding for the most part
only con is when you get on rough roads its really rough but that might not be the shocks it could be the road
Old Sep 29, 2004
Ledbelly's Avatar
oh and your not gonna find a 16mm drill bit .... . its 5/8ths wich is like 15.895463519 mm you'll just need to round it out a little
Old Sep 29, 2004
winnerpl's Avatar
winnerpl is an unknown quantity at this point
will tokico's support a front drop of 2.25 inches?
Old Oct 12, 2004
chrisleecool's Avatar
^^^ itz not good to go lower than 1.7" on tokicos , but u can try it i guess?
Old Oct 12, 2004
ctv's Avatar
ctv
ctv is an unknown quantity at this point
I just installed Tokico Blues on ym 04 Civic ex this past weekend
I found you have to use a zip tie to hold up the bump stop
the steering tie rod end holes needs to be about 2mm larger
and the mounting holes on the lower part of the strut need to be enlarged.
i did all this with a cutter bit and a dremmel
Old Oct 14, 2004
slowvic's Avatar
slowvic is an unknown quantity at this point
I have hp's on my 03. I sent the struts to a machine shop to open the bottom holes to 16mm. I also used a 01 bumpstop which fits snug on the strut rod. Do not try to use 14mm knuckle bolts on a 03+, the struts will move.
Old Oct 14, 2004
jttegx's Avatar
OMNES AD UNUM
so i would able to go down honda and purchase 4 bumpstops from the 01 civic model and it'll loop right on my 03 struts poles? meaning no zip-ties would be nescessary in my installation then right?
heres what my 03 bumpstop looks like, whats the differ between 01/02?
raymondxcho
Sep 29, 2015 09:00 PM
sccarally
Texas
Sep 27, 2015 03:33 PM
68camerors
Sep 24, 2015 06:18 PM
MamaBear2015
Sep 4, 2015 09:04 PM
