Wd-40
Old Sep 1, 2004
ZdS03Civic's Avatar
ZdS03Civic is an unknown quantity at this point
Thumbs up Wd-40
To the people who have clanking and popping in their suspension, try lubing your suspension with WD-40. I have Ground Control Coilovers that clanked and popped and squeaked when I turned. All I did was lube the hell out of the front and rears (all parts except the spring itself) and to my suprise, no more clanking(front) or squeaking(rear). I would recommed trying this before you order 01 uppermounts or spring isolators, it may solve your problem.
Old Sep 2, 2004
half_n_half17's Avatar
half_n_half17 is an unknown quantity at this point
shouldn't you use a lube that doesn't degrade rubber?
Old Sep 2, 2004
jttegx's Avatar
OMNES AD UNUM
i tried that but the clanking and clunking came back after few miles. i didnt put on shitloads but an large amount. im thinking about using grease and heard it works much better than wd-40 since wd-40 doesnt last as long as grease.
i didnt know the rears also made noise? =\
Old Sep 2, 2004
ZdS03Civic's Avatar
There isnt rubber on Ground Controls.
Old Sep 2, 2004
ZdS03Civic's Avatar
When I said shitload, a meant a good amount (not excesive)
Its been 3 days and still no clanking.
My rears sqeaked a little but the oil fixed that
Old Sep 2, 2004
518's Avatar
518
518 is on a distinguished road
From my understanding and readings on the board, the reason why it squeaks (esp the front) is that the suspension tries to turn when you turn the steering wheel. Also, the suspension should not move at all when you turn the wheels. Having said that, you are only making the suspension turn smoother when you turn the wheels.
By making the suspension turn smoother along with the steering wheel, you are only making the cause of the problem (suspension turning with the wheel) easier with your hearing.
Sure the clanking or squeaking is gone, but has the problem (suspension turning along with the steering causing it to make noise) been resolved by lubing?
I believe that lubing is only a quick-fix but to really address the problem, 01 upper mount should be used to make the rubber bushing seat properly.
Old Sep 2, 2004
rijowysock's Avatar
ThE FaMiLy SeDaN
lithium grease ;-) =bettttttter
Old Sep 3, 2004
jttegx's Avatar
OMNES AD UNUM
where can i find this product and how much (estimate) ?
Old Sep 3, 2004
home depot for like 3-4 bucks..
Old Sep 3, 2004
ZdS03Civic's Avatar
I read that the noises arent harmful, just bothersome.
Old Sep 3, 2004
nope not harmful... just annoying.
Old Sep 3, 2004
FattyMcJ's Avatar
Addicted to the Twisties!
The rear squeeks (most likely) because of yer upper control arm joints. That was the problem (or annoyance) with my old EM2.
The front pops because you messed with the geometry of the suspension (NOT what it was designed for) It's annoying, but I never had a problem with it.
(^^^OVER simplified version)
Makes me laugh when people expect to "slam" the car and have it feel/drive/sound just like it did when it was stock. What people don't realize is that, if Honda designed the car to be dropped...it would have come dropped from the factory....but it didn't. Honda put TONS of man-hours into the R&D of the suspension, and people think they can mess with it for a day and some $150 springs, and get it right? Nope...lol...it's gonna take a bit of effort to get the suspension where you want it.
BTW...use grease, WD-40 is BAAAD for parts as it promotes corrosion (sp?). Every time I've used it on something metal, the damn thing ends up rusting or even breaking (mostly bolts, etc.). Grease the fockers (if you want a quick fix) and don't worry about it....it's a Honda! lol
Old Sep 4, 2004
jttegx's Avatar
OMNES AD UNUM
sometimes even embarassing. im paralell parking in the city and these ppl walk by thinking "whose dying?" lol j/k but its embarassing at times..
Old Sep 4, 2004
Wolfgang5884's Avatar
mmmm Lithium
Old Sep 6, 2004
ZdS03Civic's Avatar
Alright I will use Lithium grease in the future. I doubt using WD-40 for one time will cause any damaged. I'll wipe most of it off next weekend and put some Lithium grease on instead.
DAC
Jun 18, 2015 10:00 PM
Grey
110
Apr 16, 2012 01:07 PM
gearbox
7th Gen Do It Yourself Articles
May 1, 2008 11:50 PM
streetglower
39
Apr 25, 2006 11:10 AM
ELaudio
Detailing
Mar 14, 2004 06:18 AM
