new tie rod boot=alignment?
Old Aug 28, 2004
Big Baller L's Avatar
Nugget Garage Since 2004
I just changed my busted tie rod boot with one from honda, and i wanted to know if i need to now get an alignment. I just popped it out of the strut put the new boot back in and put it together. I did not move the strut in any direction when the tie rod was out, so i dont see how i could need an alignment, but i wanted to ask anyways.
another question i have is how people stopped there exhaust from rattling on the rear control arm. Im really low in the back, and thats the only thing clunking. I know others must have had this problem so what did you do?
Thanks
Old Aug 28, 2004
robbclark1's Avatar
Retired suspension supermod.
Yes, you should get an alignment because the tie rod adjust the toe. You put in a new tie rod that may not be in the same position as the old one so it is a good idea to get one. Not necessary, but a good idea.
I wrapped a piece of engine hose around the sway bar and used a metal screw clamp to keep it in place. I know it still hits, but it doesn't clang around anymore.
Old Aug 28, 2004
TeLLy's Avatar
Yes, it's an Acura EL
I did the same with my rear sway bar, but I'm still bangin exhaust against the rear control arm as well...gotta find something more secure for that.
Old Aug 28, 2004
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
if you removed and changed the boot, i.e. the rubber protector around the tie rod and simply pulled it off, then put it on, your alignment is not changed.
Old Aug 28, 2004
robbclark i just changed the boot, not the entire assebly. The steering wheel is still in the same position, and the car doesnt pull to one side or the other. You think i still need one? Maybe ill put something in between the control arm and the exhaust. It sucks cuz its the only thing that makes noise over bumps.
telly:lemme know whut u find out man. Clangin' sucks!
rickinthescv:yeah i changed the boot, but i mean obviously the ball joint moved around when i was trying to get it off. I tried to put it back the same way so you think im fine? How can i tell if my toe is off?
Old Aug 28, 2004
robbclark1's Avatar
then no. I thought you changed the whole tie rod. Sorry, I misread. It is fine.
Old Aug 28, 2004
^cool man thanks alot! Saves me sum cash
any more suggestions for control arm and exhaust hitting? Maybe midas can bend it or something?
Old Aug 29, 2004
robbclark1's Avatar
they should. It shouldn't cost that much either.
Old Aug 29, 2004
^yah forshure....alright well as long as i dont need an alignment this thread can be locked.delete. Thanks for you're help everyone!
ricer_em2
May 11, 2016 08:09 PM
Tedverseti
Sep 29, 2015 05:41 PM
Wariogamer
Sep 29, 2015 09:49 AM
rovafa2002
Sep 28, 2015 06:57 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
