Tighten Steering
Old Aug 23, 2004
civicsound0844's Avatar
civicsound0844 is an unknown quantity at this point
Tighten Steering
I am wondering how to tighten my steering. I got a 02 Ex and the steering is extremly loose. Is that a stock problem? I did a search and couldnt find anything on this.
Old Aug 23, 2004
streetglower's Avatar
if you want it tighter, get rid of your power steering. Only way I can think.
Old Aug 23, 2004
irishtemper's Avatar
irishtemper has a spectacular aura aboutirishtemper has a spectacular aura about
Maby if you could get a firmer damper to fit, that might help.
Old Aug 23, 2004
blouisgod's Avatar
Life Begins > 6800rpms
what tires and rims are you running?
Old Aug 23, 2004
Zzyzx's Avatar
Autocross Junky
Define Tighten better please...
other wise, welcom to honda... and the Infamous "Honda steering Dead Zone"... where you can turn the steering wheel an inch or two from dead center and not much happens....
Old Aug 28, 2004
I have stock right now. And what I mean by tighten is that when you turn the wheel I actully want the wheels to turn. Right now I can turn it pretty far without it turning at all. I want it to turn the steering wheel alittle and have the wheels start turning. Thanks for the help!
Old Aug 28, 2004
Boilermaker1's Avatar
Jap-Euro Fusion
Well, you can swap the box for a quicker ratio, or put some toe out in the front, but then you're wearing the tires faster. Just buy some tires with stiffer sidewalls, thats probably the easiest way to make the steering more responsive.
Old Aug 29, 2004
Okay. Ill try that. Thanks alot everyone!
Old Aug 29, 2004
tfnaaf's Avatar
BLDNPSI Mod
be sure to have the front end checked just to be on the safe side to make sure nothing is physically worn out and unsafe
Old Aug 30, 2004
gtracing's Avatar
TeLLy is my daddy
gtracing is an unknown quantity at this point
get a smaller steering wheel...i changed mine and i lost it...but i have a problem with my p/s tho, when i take large turns the power steering will cut right off, and it pisses the **** out of me because i'd be trying to park, and all of a sudden the power steering will cut off...went to acura to check it out, they couldn't tell what the problem was...i didn't change the pulley, just suspension....
rovafa2002
Sep 28, 2015 06:57 PM
2002ExCivic
22
Sep 28, 2015 08:29 AM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
Joecrowe
Sep 24, 2015 09:12 AM
Yang559
Transmission
Sep 21, 2015 01:41 PM
