will rsx coilovers bolt up on sedans?
ive been told that rsx coilovers or for that matter suspension in general will swap right over. is this true. i have a friend with a rsx that totaled it. he already sold the motor and tranny but wants me to buy his tien coilovers and his sways. ive read here that the sways will work but will the coilovers just bolt right up or will i need to make modifications at all? thanks..........Jacob
They should work, but you might need new tie rod ends as the RSX ones are slightly larger. Also, the mount bolts might be different. But other than the tie rods and the mount bolts, they should work just fine. Just check the measurements on those bolts.
now correct me if i am wrong but i will need some kind of adaptor to put the rear bar on my car since it is a lx right? it is like a clamp for the lower arm if im not mistaken. has anyone that you know of used coilovers off of a rsx? and do they make a kit to adapt the rear sway? thanx for you time guys ive tried to research this but could not find any definate answers.
if you have a 2k1 lx, then you will need endlinks and brackets/bushings. You will also have to drill holes in your subframe. Progress makes a kit.
I don't know of anyone with DC5 coils. I have EP3 coils, but they were guarenteed to fit because the tie rod ends and mount holes were the same. The changed the mount holes for different years on the civic. All you have to do is go to Home Depot and pull out some 14 or 16mm bolts and see what one goes through the mount holes and the tie rod ends.
anyone have a link to the progress adaptor kit? i dontr think im going to be using the coilovers. id rather do something right and i know the coil rate and shock valving wont be correct for my 4dr vs a rsx. im leaning twords the b+g's right now. anyone have a better suggestion as to another brand i should look at?
EM_WON
Jul 22, 2015 06:49 PM
muttleytm
Jul 14, 2015 05:31 PM
