Need Help Coilover Install.
Old Aug 13, 2004
intelonetwo's Avatar
intelonetwo is an unknown quantity at this point
I have installed a set of coilover sleeves on my 2002 Civic LX and everything goes together fine in the front suspension, but the rear is where I am having problem getting the car to lower.
I used the DIY yourself page to get instructions on the spring install, but with coilovers I must be missing something to remove on the factory shock assembly because when I lower the vehicle the car does not go the approriate lowering amount. Should I have remove a certain washer, nut, or shock piece. Any help would be great.
Old Aug 13, 2004
robbclark1's Avatar
Retired suspension supermod.
the rear takes some time to settle. It does not have the weight of the engine. You can jump on the trunk or give it a few days to let it settle.
Old Aug 13, 2004
Thanks for the reply, I do understand that the rear suspension takes a bit of time to settle due to the reduced weight.
When I lower the car down from the jack stands after installing the coilover setup, the vehicle still looks like it is at stock height no matter what lowering height I have selected on the coilover setup. Any thoughts?
Old Aug 13, 2004
MrWong's Avatar
Bushido
MrWong is an unknown quantity at this point
The best way to determine that is to measure the ride height with a measuring tape each time you lower it to see how low you are going.
Old Aug 13, 2004
MrWong,
I appreciate your suggestion, and I have been measuring ride height, and each time I am getting the same measurement. Stock height. I believe that I may have a solution to the problem now, however. I think that I need to not include the stock washer that goes on the thinner neck of the stock shock rod, this will allow the coilover top ring/large washer to depress the shock when necessary.
Old Aug 13, 2004
jttegx's Avatar
OMNES AD UNUM
how long did u wait for it to settle? give it like a day or 2 with regular driving.
what kind of coilovers are they btw?
Old Aug 14, 2004
To get a midlevel drop, do I put the tightening ring half way up the sleeve, or do I put it at the top or bottom?
I have the dropsone coilovers which I believe, and know arent the best, but that's what I have to work with.
At this point I am ****ing up to many things to continue to mess with the whole thing. I have stripped a lug stud and bolt, i have also stripped 3 of the 4 strut tower bolts. So this is begining to get expensive. I could just purchase the correct springs and call it a day.
Old Aug 15, 2004
StaticX's Avatar
StaticX is an unknown quantity at this point
you know what dude, i had the same problem with a set of coilover! OmG it was soooooooooo frustrating. After 4 install attempts with no proper drop, I ended up purchasing a set of neuspeed racing springs and a SPC camber kit and called it a day.
Old Aug 16, 2004
What up static, I did the same thing this evening. I just purchased a set of Dropzone springs and also called it a day. I do need to purchase a camber kit though. My drop is only 2"'s and does not look like it needs a kit.
Old Aug 16, 2004
VNlilMAN's Avatar
The Standard One
well just because you place the perch on the middle doesnt mean your going to have a drop thats halfway from stock to no gap. try dumping the perch all the way to the bottom, if its still at stock height than yeah somethings wrong but i'm sure this will solve your "problem".
Tedverseti
Apr 23, 2020 01:45 PM
GolNat
Nov 27, 2018 03:32 PM
wingsfan19
Oct 1, 2015 03:45 AM
Tedverseti
Sep 29, 2015 05:41 PM
beanhead
Sep 24, 2015 12:04 PM
