chamber
Old Aug 8, 2004
02sleeper's Avatar
Boosted Auto Sedan Project In Progress
02sleeper is an unknown quantity at this point
chamber
Ok i know that alot of people here have a chamber kit and put it way negative in the back isnt there alot of things that go wrong when you do that like tire wear major. and other stuff like that well if you could tell me what are the advantages and disadvantages it would be deeply appreciated
Old Aug 8, 2004
streetglower's Avatar
I am confused. What do you mean by they put it way negative? The whole point to having a camber kit is to correct your alignment after dropping it so your tires dont wear. Without the camber kit, your alignment will be out.
Old Aug 8, 2004
abmerop18's Avatar
Jam out with your clam out.
first off, its a camber kit not chamber.
and 2nd people get a camber kit to fix negative camber from a drop, not to add negaive. with a camber kit people are adding positive camber to correct their alignment.
Old Aug 8, 2004
LMAO.
Old Aug 8, 2004
Boilermaker1's Avatar
Jap-Euro Fusion
Well some of us did get camber adjustment devices to add negative, but we do it in the front. There's no way to get a whole lot out of the stock bolts without some help. As far as the back, when you lower it, you flatten the lower control arm out and it pushes the camber negative, you get the adjustable length upper arm to increase its length to push the top of the tire back upright so your camber is ok.
Old Aug 8, 2004
Mr.Modify's Avatar
why do people always call it chamber kit hahahahahahaa
Old Aug 9, 2004
Pn0ybOiLiKehOy's Avatar
Pn0ybOiLiKehOy is on a distinguished road
ive never heard that one before =P
Old Aug 9, 2004
02sleeper's Avatar
ok got ya and i did say chamber kit and akia if its not called chamber kit then what do you call it?!?
Old Aug 9, 2004
abmerop18's Avatar
its camber not chamber like i said in my post
Old Aug 9, 2004
TeLLy's Avatar
Yes, it's an Acura EL
When people around here ask me about why my rear wheels are slanted out, they say "Why don't you get a chamber kit" (pronounced as in "torture chamber"). Then I laugh and point at them. Then I drive away with a 50% contact patch on my rear wheels. Oh the humanity.
Old Aug 9, 2004
beastiek2's Avatar
This cost me 1500 points
beastiek2 is an unknown quantity at this point
It wil just save you money in the end getting a "camber" kit soon after slamming your car. You can basically see by just looking if you need one or not. I believe anything lower then 1.5 1.75 inches needs one. I got just about a 2 inch drop and my tires where starting to look like the DeLorean before it flew back in time. Just get one its cheap and will save your tires.
Old Aug 9, 2004
Mr.Modify's Avatar
Old Aug 9, 2004
dirtySAMURAI's Avatar
I log in from time to time
chamber kit....
Old Aug 9, 2004
02sleeper's Avatar
hey thats not cool
Old Aug 9, 2004
TeLLy's Avatar
It's OK man we still love you.
Old Aug 9, 2004
02sleeper's Avatar
right.......... lol
Old Aug 9, 2004
Mr.Modify's Avatar
chamber kit....
hahahahah adamm i like that one
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
carid
Nov 7, 2015 01:46 AM
opto_isolator
Nov 4, 2003 09:53 AM
