are these alignment numbers right?
Old Jul 28, 2004
fuledya's Avatar
Super Member
fuledya is an unknown quantity at this point
front left toe = 0
front right toe = 0
front left camber = 0
front right camber = 0
rear left toe = .10
rear right toe = .10
rear left camber = -.2
rear right camber = -1.3
thrust angle = 0
total toe = 0
Hayame full coilovers
Eibach front amber kit
Ingalls rear
1.5" drop
2001 Ex coupe
Old Jul 28, 2004
tfnaaf's Avatar
BLDNPSI Mod
i dont recall the specs off hand cause i align about 5-10 cars a day. but it basically all looks good but the right rear camber, by the way what were the caster readings?
Old Jul 28, 2004
fuledya's Avatar
Super Member
caster was 1.9 left, 1.7 right - he said this was just a baseline cause caster is non adjustable on civics. He said my alignment was within specs, was he wrong? I'de hate to have it done again......
Old Jul 28, 2004
Boilermaker1's Avatar
Jap-Euro Fusion
Thats a pretty shitty alignment as far as handling goes... but your tires should last just short of forever.
Old Jul 28, 2004
fuledya's Avatar
Super Member
Boilermaker1, please expain
Can you give me a good argument to have him adjust it w/o getting charged another $70? - what did he do wrong?
Old Jul 28, 2004
tfnaaf's Avatar
BLDNPSI Mod
i would have the right rear camber addressed, or you may get inside edge wear. and as far as the caster your correct you cant adjust it but its good to know what its set at
Old Jul 29, 2004
Zzyzx's Avatar
Autocross Junky
Its bad for handling because you have 0 negitive camber on the front end and you are running .10 Toe in on the back... Thats going to make the car understeer... Alot. Great for keeping grandmas and Idiots safe, but not good at geting you around a corner quickly. BUt Boilermakers right, your tires should last about aslong as they can last (Given your tires tread wear)
Old Jul 29, 2004
phatcyclist's Avatar
phatcyclist is an unknown quantity at this point
well, stock camber setting in the rear is -1.5 degrees, so one of your control arms (or camber kit) is WAY off.
Old Jul 30, 2004
gotrice's Avatar
gotrice will become famous soon enough
could you install a camber kit yourself or are you better off taking it to a shop? i dont understand the whole concept of having them aligned right so that your tires last forever oppose to having them align so that you have better handling, how do i know or figure that out? i have a goldline setup with a drop of 1.75" and only my rear tires have toed in and whenever i take in sharp turns i can feel traction lost. how do you measure for camber settings?
Old Jul 30, 2004
Jap-Euro Fusion
with a camber gauge naturally.
Old Jul 30, 2004
TeLLy's Avatar
Yes, it's an Acura EL
You have a camber kit, I don't see how they could have left that rear camber like that.
BTW I'm on Hayames too, my rear camber is -1.5 and -2.9 respectively for left and right. NO camber kit. How could you have similar camber if you have a kit to correct and adjust it?
Old Jul 30, 2004
CrazyCakes's Avatar
CrazyCakes is an unknown quantity at this point
your rear camber should be addressed just because of the side to side variance. i belive stock specs for rear is .16 toe in and -.75 camber (degrees). i'm running -1.6 front camber -.8 rear and 0 toe all the way around and handleing is awsome. but tire wear is gonna suck.
Old Jul 30, 2004
Zzyzx's Avatar
Autocross Junky
^^ with -1.6, your tires will still last Quite a while.. Toe settings (In or out) will eat tires MUCH quicker then camber settings.
Old Jul 30, 2004
halflife's Avatar
halflife is an unknown quantity at this point
Feel Good I just paid 225 for an alignment
Old Jul 30, 2004
tfnaaf's Avatar
BLDNPSI Mod
ummmmm.....u got got screwed!
Old Aug 2, 2004
PrimeDynasty's Avatar
PrimeDynasty is an unknown quantity at this point
I am going in to get my alignment done tomorrow. I just put in my Neuspeed Race Springs and need to get everything lined up again. Do places even let you specify if you want a certain setting or do you just have to get it all straightened out and then do it yourself?
I am kind of looking for a balance between good tire wear and good handling so what would be a good setting for toe, camber, etc.?
Old Aug 2, 2004
fuledya's Avatar
Super Member
anyone else? so does anyone know the actual spec ranges front and rear for our cars? Im thinking I may be within specs, just low on the left rear side and on the high end on the right rear, maybe still within spec, just not even side to side???
solarpunk70
Apr 12, 2016 11:43 AM
Tedverseti
Sep 29, 2015 05:41 PM
Wariogamer
Sep 29, 2015 09:49 AM
khatib
Sep 9, 2015 10:50 PM
