Tein`s for 04 Sedan
Old Jul 26, 2004
Superman2004's Avatar
Superman2004 is an unknown quantity at this point
Tein`s for 04 Sedan
Has anyone had any trouble with the Tein`s lowering springs on thier 04 sedan? I tried putting them on this weekend. The front look according to spec, but it put the rear all up in the fender well. There is no way it only dropped it 1.25 in the rear. I had to end up cutting the stock spring slightly and leaving the tein on the front in order to get it to look even.
Has anyone else experienced this? I was really dissapointed.
Old Jul 26, 2004
Goober's Avatar
Goober is an unknown quantity at this point
Same thing happened to me last year. S. Tech springs are not made for sedans, unless you like you rear end lower than your front.
Old Jul 26, 2004
so what set up did you go with?
Old Jul 26, 2004
Goober's Avatar
Get different springs. Neuspeed and goldline make springs specifically for our sedans.
Or you can get Koni's and set the rear on the high perch setting.
Old Jul 26, 2004
thesparkleman's Avatar
thesparkleman is an unknown quantity at this point
You can also get the Tein SS or something else adjustable.
Old Jul 26, 2004
VNlilMAN's Avatar
The Standard One
eh listen to goober..
most spring manufactures dont make springs for sedans. sure they fit but since the sedan is heavier in the back, it causes it to sag. neuspeed and goldline make sedan apps, i would go with neuspeed.
Raiool
Oct 1, 2015 10:42 AM
thatcham
Sep 30, 2015 08:28 AM
dhuff
Sep 28, 2015 08:35 PM
rovafa2002
Sep 28, 2015 06:57 PM
TheRiddicles
Sep 21, 2015 01:28 AM
