Front end pops
Old Jul 25, 2004
MICHAELAMBRISCO's Avatar
MICHAELAMBRISCO is an unknown quantity at this point
Angry Front end pops
I recently put on ground control coilovers and koni struts all the way around b/c of blown stock struts and now i have a horrible popping noise when i turn my wheels either way. i also had the axle rebuilt and replaced the tie rod end on the driver side and ball joint on the same side but the popping wont stop. any suggestions?
Old Jul 25, 2004
ZdS03Civic's Avatar
ZdS03Civic is an unknown quantity at this point
I have Ground Controls and I have the same problem. Dont worry its normal with sleeved coilovers. If you want the noise to stop your going to need to buy coilover wrap. This is a special tape/wrap that keeps the metal from rubbing and making that noise.
Old Jul 26, 2004
robbclark1's Avatar
Retired suspension supermod.
Tighten the locking nut. It is because of our stupid steering arm.
Old Jul 26, 2004
VNlilMAN's Avatar
The Standard One
coil wrap might not help for it. coil wrap is usually for rattles. Who know it may fix it but the popping might be more of a bearing issue. maybe try greasing up the top/bottom perches
edspyhill09
Jun 12, 2016 02:45 PM
Lopes101
Jun 7, 2015 08:04 PM
chuffsy
May 15, 2015 12:50 PM
pheaton
May 4, 2015 08:26 PM
GH04si
Apr 15, 2015 08:13 PM
